![]() ![]() Join Date: Feb 2009
Polishing clear anodized aluminum grille without stripping
I picked up a 72 grille and it's super. Not a flaw less one hairline scratch very much on the surface. You can't feel it. As luck has it the scratch is in good spot. You'd have to be looking for it or a half-pint.
But I'd like to polish it out if possible. Has anyone had success polishing any level of scratches without harming the existing surface? I've read many times that NOPE, you have to remove all the anodize and start over. I described the scar to Eastwood for "Autosol Anodized Aluminum Polish." They said "That product would certainly remove the scratch out of the grille on your vehicle."................................The description and label seem to be a contradiction "Anodized Aluminum polish" & "For un-coated aluminum surfaces". I'll probably buy a tube and test on the spare. Here's another product I'm inquiring on. It's for oxidation anyway, on what he describes as very hard anodize. I don't see that tool on the grille though. the scratch is not on a flat surface. But a Dremel may work. https://mercedessource.com/tech-help...um-window-trim
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
Re: Polishing clear anodized aluminum grille without stripping
You will need to sand the clear off and polish it.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
I reject that answer
You cant clean the garage standing outside, with the door closed...
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
subscribed
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#6 | |
![]() When people say strip & polished, the polish is a cleaner an moderate protector right? Seems you'd want to seal it somehow. I heard back from the Mercedes folks "I am not sure if our trim polish would work on this trim we have never tried it on a Chevy trim you could send some pictures and we could try and determine if it is the same as the Mercedes"
#7 | |
No, it is a clear spray coating.
![]() Join Date: Dec 2013
4 choices ,
1) leave it alone 2) spend untold hours stripping /polishing and maintaining forever... 3) power coat it. $$ 4) have it chromed . $$$$ |
![]() Join Date: Jul 2015
I have seem them CHROMED, and yes they stand out like that.
Not a one an acceptable answer.
Chrome is definitely bright. Powder coat is probably nice, I'd like to see that.
![]() Join Date: Oct 2009
I've only seen a few pc'ed, and have yet to see one that rivals an anodized finish, let alone chrome. I'd leave it alone unless you're in the final 8 for the Riddler, THEN maybe...
Chrome on the left aluminum on the right
try polishing compound on another similar part. then if it works try it on the good one. also you might try a good paste wax. My understanding (someone will correct me if i am wrong) is that anodizing is like clear coat that is electroplated on instead of sprayed on. if that is true, you should be able to fix it like scratches in paint. But if it were bubbling or flaking off, or cracked like on a part that were being repaired then i would say that is another matter entirely.
just suggestions, but that is what i would try first if it belonged to me. please tell us how it turns out and what you end up doing. and remember we love pics. best of luck to you sir. Tony
i survived cancer and kidney stones, but my kids are killing me. |
#14 | ||
Until now I figured the bezels were chrome to begin with. Never put much thought into it. Sick and tired of learning new stuff man...........Just kidding.
If you watch the Mercedes guy, he's tried near everything and ended up bottling his own. I did not use a power tool or anything that resembles an abrasive pad.......No way, not yet anyway. My spare still has a nice hard finish. Plenty of scratches to choose from too, so I'll likely make a go of that using at least the first product in the OP, Autosol Anodized Aluminum Polish. If any scratch can come out it's this one, but at this point I'm real skeptical about Eastwood's response that it works. The finish is very hard, it's nothing like paint or clear coat.
#15 |
You could try this
https://sciencing.com/repair-anodize...s-7899695.html , Or just hand it to the chrome shop ? ![]() |
#16 |
I thought all this was supposed to be fun ?
#17 |
![]() Join Date: Mar 2000
Anodizing is very very hard and incredibly thin. If you make it shine and remove the scratches you will have removed it all and polished the aluminum.
Saskatoon, Saskatchewan Canada |
#18 | |
Interesting. Chrome shop does chrome, so nah. ![]() Sometimes it's just not that fun. Keeps the brain going at least.
#19 |
Yeah I think there's no way around one of the options Grumpy old man listed. I too, foolishly, tried to polish my trim with regular metal polish. It didn't even phase the anodized aluminum. If the scratch is in the aluminum, then the aluminum needs to be repaired even if only through light sanding. To get to the aluminum, you have to go through the anodized coating. There's physically no way around that. If you go through the anodizing, then that spot will now be bare aluminum which will polish up to an amazing shine... but now the rest of your grill is still faded anodized! I spend DAYS sanding off the anodized coating (yes, sanding!) from my old Malibu trim. It was totally the wrong way to do it and tons of aggravating work, but when I was done, wow did it shine! Of course, it required a quick polish every 2-3 months to keep the shine but, man it was shiny! Did I mention how great it looked?
Builds: Green Gus the 68 C10 | Bluey the 72 1500 | Lowly the 70 C10 - Instagram: @dr.hewitt - C10 Concept/Development Photos: Master Thread |
#20 | |
It's thin and you brush it on. Haven't touched my grill since stripping and polishing and looks great Chrome shop quoted me $1,600 Google it. Only $24 Check out my link on it. Better pics too http://67-72chevytrucks.com/vboard/s...d.php?t=741548
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com Last edited by rockyrivermark; 12-21-2017 at 09:58 AM. |
#21 |
![]() Join Date: Jul 2001
Subscribed to this, maybe hope after all for my Chevelle rocker moldings.
1971 Chevy 1/2T 4x4 LWB 350 V-8 Was sm465-now 350TH/np205 Tilt, Tach, Towhooks Original Truck AM/FM Wellington, Ks |
#22 |
Oh you bring another character to the party... damage and pitting from debris...
#23 |
![]() Join Date: Nov 2013
love the pic
Protectaclear is 85 in Canada ![]() Last edited by ho70; 12-23-2017 at 09:45 PM. |
#24 | |
220 320 400 600 1000 1500 Polished with mothers aluminum and mag polish Then coat with protectaclear. It's work but maintence free once coated. Takes about 2 hours.
My build page http://67-72chevytrucks.com/vboard/s...d.php?t=764662 My cabinet building site http://www.cbcabinets.com |
#25 | |
