SM465 Clutch kit suggestions?
Anyone have any suggestions on what brand/type of clutch kit to get for a 72 C20 350 with SM465? Pretty sure its a 11" clutch. Not sure weather to go ceramic or organic clutch disk, self aligning vs regular throw out bearing, etc. What do you guys use? Also anyone have a link/part number for a poly version of the rubber mount that the trans sits on the cross member? I already have the engine mounts I would just like to replace that mount. Thanks.
Re: SM465 Clutch kit suggestions?
IME, most SM465 clutches are 12". I would just buy a complete clutch kit off RockAuto. Most run about $100.
If you are lucky, you may score one on Clearance. I bought a complete one with a puck style metallic clutch for $40. :-)
![]() Join Date: Feb 2002
A '72 flywheel will be 12''. '71 and earlier will be 11''.
I used the Centerforce II clutch set up on both my '71 GMC Jimmy w/ V8 350/SM465/NP205, and also '68 C/10 w/ 292 L6/SM465.
Oh okay. So this flywheel won't work with a 5.7 vortec and 12" clutch? https://www.summitracing.com/parts/n...8/applications
If you don't have the original '72 12" flywheel, then I don't think the universe will come to a screeching halt if you used an 11". But I could be corrected. The SM465 didn't get a 12" flywheel til MY 1972. '68 thru '71 SM465s used the 11". I guess the 11.85" is called the "Twelve Inch."
If they're the same price get the bigger one.
My '69 SM 465 K-10 has a 12". I am pretty sure it came that way.
'69 Longstep K-10: 327/SM465/T-221/Closed Knuckle Dana44/12-bolt. |
All about them Ks
![]() Join Date: Jun 2014
I got a 12” luk from NAPA for my K20. I was around $120 for everything except for machine work to my flywheel.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5 lift, 35s, front dana 60 blah blah blah http://67-72chevytrucks.com/vboard/s...d.php?t=662879 69 K10 SWB: 4 lift 33s in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20s |
I used a Luk clutch with my 3 speed. They are original equipment on a lot of GM cars and trucks. Which exact one for your application? I'm not sure, but I can't imagine there is too many different clutches for these old trucks. Probably only a couple of sizes?
![]() Join Date: Nov 2006
oreillys are lifetime guarantee for around 100.00. organic is oem and easyiest on flywheels. 12 in if it will fit but 11 h/d would be more than enough.
I BELIEVE IN JOHN 3:16 |
I guess i'll have to tear the engine out and look at the clutch to see for myself. Seems like its either 11.85" or 12". It kinda matters because the flywheel I was looking at takes a 11.85 max. Steel or cast flywheel by the way?
The OEM flywheel will be cast iron.
#12 | |
Steel or cast-iron? IDK.
no need to pull engine or trans............ just slide trans back about 8 inches. steel flywheel not needed. cast is fine in fact just resurface it. new pilot bushing and throwout brg. I don't think a 12 in will fit in our bellhsgs. 11 in is biggest. been a while. check clutch fork for wear............
#14 | |
All about them Ks
