Old 05-24-2018, 05:13 PM   #1
Stocker
20' Daredevil (Ret)
Stocker's Avatar
A/C condensor pusher fans
Had a third shop work on my A/C and it finally seems good.... with one exception. I was told I need a couple pusher fans in front of the A/C condensor, because at low speeds (or at idle) there's virtually no air passing through the condensor. It's in the stock position but sits too far from the radiator. With a big gap at the top and a smaller gap at the bottom, most air to the radiator is bypassing the condensor.
If any of you have added pushers in front of your condensor, what did you use? I searched a bunch of threads but didn't find what I'm looking for. Summit has thousands of fans and it's hard to know where to start. Thanks for any help!
- Mike -
1972 K20 LWB 350/350/205
RIP El Jay
Old 05-24-2018, 10:43 PM   #2
Stocker
20' Daredevil (Ret)
Stocker's Avatar
Re: A/C condensor pusher fans
Nevermind..... Found 12-inch Hayden 3680 fans locally, did some more research and decided to mount a pair of them to the condensor. They'll be triggered by the hot lead to the compressor, using a relay & fuse of course.
- Mike -
RIP El Jay
Old 05-24-2018, 10:51 PM   #3
davepl
davepl's Avatar
I have a big pusher-puller sandwiched between the radiator and compressor. Definitely helps with engine cooling at hot idle with the AC on, and the AC works, so I guess both work!
It'll still slowly climb in temp at idle on a hot day though.
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 05-25-2018, 06:51 AM   #4
CaptRMW
Custom Sport W/T
CaptRMW's Avatar
Location: Tarpon Springs,Fl & Annapolis,Md. ....................Quaint drinking villages with a fishing problem
Good results with thishttps://www.ebay.com/itm/Brand-New-16-Inch-Radiator-Cooling-Fan-W-Mounting-Kit-1500CFM/122349081088?ssPageName=STRK%3AMEBIDX%3AIT&_trksid=p2060353.m1438.l2649
CaptRMW is offline   Reply With Quote
