Old 09-21-2014, 07:08 PM   #1
farmall
farmall's Avatar
81 K30 Flat Bed
This is what it looked like at the POs place. Not very pretty. He was asking $1350 for a long time and I got tired of seeing it so I offered $850. Took it to the closest gas station fueled it, aired up the tires, and drove it home. It has a 454, TH400, NP205, 3:73s, Try Y headers, Edelbrock performer low, and a Holley.
1955 GMC 250 8 Flatbed
1971 C30 157" 350 4spd 10' Flatbed
81 GMC K30 CnC 9' Flatbed 454 T400
89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958
71 LT1 Convertible, 72 Coupe
69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2
farmall is offline   Reply With Quote
Old 09-21-2014, 07:44 PM   #2
rusty76
rusty76's Avatar
Re: 81 K30 Flat Bed
So what's the plans for this rig?
http://67-72chevytrucks.com/vboard/s...d.php?t=581873
The low buck build threads. Check'em out!
http://67-72chevytrucks.com/vboard/s...d.php?t=666022
My build thread
Crossmembers CC
rusty76 is offline   Reply With Quote
Old 10-10-2014, 11:37 PM   #3
farmall
farmall's Avatar
Re: 81 K30 Flat Bed
Plans are to go through it from top to bottom for use as an all season parts and firewood hauler.
So far...
I bought an 87 3/4 with cab lights for body parts.
Cleaned most of the P O out of the truck.
Rebuilt the transfer case using the 205 overhaul in the 4x4 section(big help).
Rebuilt the rear driveline.
And I cut the old exhaust off and had a new system installed.
Next project will be new VCGs (what a mess), install a PCV system and throw away the breather filters.
Old 10-11-2014, 01:55 AM   #4
MTCK
MTCK's Avatar
Re: 81 K30 Flat Bed
Cool truck. It looks ready to work.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 10-11-2014, 11:33 AM   #5
tip
Re: 81 K30 Flat Bed
Nice truck, you work fast! Any issues with the 205 rebuild?
tip is offline   Reply With Quote
Old 10-11-2014, 12:04 PM   #6
farmall
farmall's Avatar
Re: 81 K30 Flat Bed
The only hickup was the Tcase to adapter gasket. Mine had a larger ID than the one supplied with the kit. $4 bucks later it was back together. I was a little apprehensive at first but it goes together just like it comes apart. I would not have attempted it without the jbclassix writeup.
Old 10-21-2014, 12:09 AM   #7
farmall
farmall's Avatar
Re: 81 K30 Flat Bed
A promised, no more valve cover leaks or cheesy air cleaner. It still needs hours of tidying up under there. At least I dont smell of burnt oil when I arrive at my destination.
Next, its getting a tune up, a carb fine tune, oil change, and an electric choke if I can remember what I did with it.
Old 10-22-2014, 09:40 PM   #8
farmall
farmall's Avatar
Re: 81 K30 Flat Bed
Picked up a really nice Warn bumper on CL today. I have a 9000i to go in it.
Old 12-08-2014, 11:42 PM   #9
farmall
farmall's Avatar
Re: 81 K30 Flat Bed
I removed the Dana 60 for a little lovin.
Old 12-10-2014, 11:32 PM   #10
farmall
farmall's Avatar
Re: 81 K30 Flat Bed
Further disassembly and cleaning.
Removed the open carrier.
Rebuilt a Powr-Lok limited slip out of an old International and installed the ring gear today.
Next....set up the r&p.
Old 12-11-2014, 11:33 PM   #11
farmall
farmall's Avatar
Re: 81 K30 Flat Bed
R&P set up and U Joints installed.
Old 12-12-2014, 01:10 AM   #12
ol'blazer
ol'blazer's Avatar
Re: 81 K30 Flat Bed
looks like one tough truck!
Tyler
1980 2wd blazer
1985 k10 diesel truckhttp://67-72chevytrucks.com/vboard/s...d.php?t=652276
1987 wrangler 4x4 build-http://67-72chevytrucks.com/vboard/s...d.php?t=663784
ol'blazer is offline   Reply With Quote
Old 12-16-2014, 11:05 PM   #13
farmall
farmall's Avatar
Re: 81 K30 Flat Bed
Finally assembled.
All new bearing and seals, rotors and calipers, king pins, U joints, Powr-Lok and polished stainless cover.
Now to find time to get it installed.
Old 12-16-2014, 11:24 PM   #14
MTCK
MTCK's Avatar
Re: 81 K30 Flat Bed
That's pretty! I'll be curious to see how you like the limited slip in the front.
-Marcus
Project Plow Truck
Old 01-09-2015, 01:00 AM   #15
farmall
farmall's Avatar
Re: 81 K30 Flat Bed
Yes it will be interesting to see how it feels. I have never had a non selectable traction aid in the front before.
The Powr-Lok can be set up loose, several ways or tight. I set this one up loose as Spicer recomends for a front application.
Finally got around to installing it with new springs and new shocks.
Old 01-12-2015, 12:39 AM   #16
farmall
farmall's Avatar
Re: 81 K30 Flat Bed
Dropped the rear end for service and cleaning.
Old 01-13-2015, 01:30 AM   #17
farmall
farmall's Avatar
Re: 81 K30 Flat Bed
These lower U bolt cradles hold a lot of garbage. I drilled some drain holes to let the water out and make it easier to keep clean.
Old 01-13-2015, 08:51 AM   #18
77K10Silverado
77K10Silverado's Avatar
Re: 81 K30 Flat Bed
Outstanding work!
77K10Silverado is offline   Reply With Quote
Old 01-13-2015, 01:00 PM   #19
83swb
Re: 81 K30 Flat Bed
Originally Posted by 77K10Silverado View Post
Outstanding work!
x2^ Great attention to detail.
83swb is offline   Reply With Quote
Old 01-15-2015, 10:54 PM   #20
farmall
farmall's Avatar
Re: 81 K30 Flat Bed
Thanks Guys.
New Shoes, Hdw, Wheel Cyls installed and drums turned. I had NAPA turn my drums and I dont know what they did but they are cross hatched. I was just expecting a turn job.
And a pic of the 3:73 Gov Lock.
Old 01-19-2015, 12:35 AM   #21
farmall
farmall's Avatar
Re: 81 K30 Flat Bed
Finished the rear end and powerwashed the rear underside.
Old 01-19-2015, 10:27 AM   #22
77K10Silverado
Re: 81 K30 Flat Bed
How did you clean your axle housing before you painted it? What kind of paint did you use? Looking great!
Old 01-19-2015, 10:26 PM   #23
86454k30
86454k30's Avatar
Re: 81 K30 Flat Bed
nice build! Glad its getting redone rather than parted out. Good job on the detail.
86454k30 is offline   Reply With Quote
Old 01-20-2015, 01:51 AM   #24
farmall
farmall's Avatar
Re: 81 K30 Flat Bed
Thanks 86.
NAPA Super Clean is the purple stuff everyone sells. Purple Power ect... It is slightly acidic so it removes rust as well as grease. It also takes the gloss off anything shiny it is sprayed on at full strength. It also dulls shiny aluminum and is very nasty to the eyes and respratory system. I get it in the 2.5 gal bottles and spray it full strength from a bug sprayer. A 4000 psi pressure washer with the pencil tip takes everything off after soaking.
Rustoleum Pro.
New springs arrived, new U Bolts, cleaned and painted my overloads. When all that is dry I will reassemble the spring packs with the overloads and the BFG Velvet Rides.
Old 01-20-2015, 04:42 AM   #25
y5mgisi
Second Chance Program
y5mgisi's Avatar
Re: 81 K30 Flat Bed
I like it.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
