Reverse lights problem
I’m working on getting my lights, signals, etc. working properly. The reverse lights did not have bulbs in them. I picked up a pair of 1156s and installed them. The reverse lights only work when the shifter is in drive.
How do you adjust this and does it affect the neutral safety switch? Thanks |
![]() Join Date: Nov 2018
Re: Reverse lights problem
The switch that controls your back up lamps and NSS is at the top of the bottom of the steering column inside under your dash.
Not knowing what someone may have done is first make sure the wires are plugged into the correct spades. Easiest method to insure correct position is to use an Ohm meter on the NSS tabs, put the shifter in the neutral position the move/slide the switch until you get an open/resistance reading. If everything is as it should be your reverse lights should now also work. |
Thanks, I’ll try that tomorrow!
