Old 07-09-2018, 06:13 PM   #1
virginiacreeper
Temp sending unit
I've a 1960 Apache 20 that I installed a slightly newer small block in and didn't really see a good spot to put the temp sender in so I got a Glowshift inline piece. This takes a 1/8 27 NPT sender but I believe the stock sender has much lower resistance than most current senders. Anyone know of a 1/8 sender that has the correct values for the factory gauge? Ideally, it would be two wire as the inline piece is insulated by the radiator hose.
Thanks! Ray
virginiacreeper is offline   Reply With Quote
