Help Finding a lower rad hose
Water pump is 1 3/4" and lower rad neck is 1 1/2" and the elbow is probably just a standard 90 degree. Anyone have any part numbers?
Please and thank you. |
Re: Help Finding a lower rad hose
Go to your local auto parts store and have them look up the sizes in there books.
LIL ERV the 50-3600 396 BBC stroked to 415 cid Richmond 6spd over drive C4 rear Porter built a arms Never give the Devil a ride,because he'll want to Drive! |
sorry, no part numbers, BUT, I'd suggest you mock up a hose using hand towel tubes or go buy some flexible tubing and make the shape you need. you should be able to find a hose with 2 different size inlets
![]() 1940 Ford Dlx Coupe 1969 Mach1 |
![]() Join Date: May 2007
what motor what rad what truck?
and if its an AD with a SBC and a stock style rad look here. http://67-72chevytrucks.com/vboard/s...d.php?t=768479
![]() ![]() Join Date: Mar 2016
Napa 7344 or 7648 depending on where you need the length of the long side. or you can use an 1-3/4" hose with a reducer to 1-1/2" #901
'35 1/2 ton Pickup (bought 2020) '68 C10 Suburban (bought 2021) '72 K5 Blazer (bought 2013) '67 Stepside (bought 1997-sold 2021-partially bought back 2024) '96 Bronco Eddie Bauer (inherited 2010) My 1st day here-'67 C10(sold)and '72 K5 Blazer http://67-72chevytrucks.com/vboard/s...d.php?t=702056 "Another Blue Chevy"(1935) http://67-72chevytrucks.com/vboard/s...d.php?t=799203 ![]() ![]() |
Active Member
![]() Join Date: Sep 2016
Gates has a reference guide, (pdf) chart of molded hoses online. Download it and it has inlet and outlet sizes and length. When I did my chevelle, I found a half dozen that might be close then went to the parts store had them look up or cross reference the number, which had a pic attached so I could see what would work.
72 K10 swb in progress 67 C10 swb 66 chevelle SS Conv 40 Plymouth pickup ![]() |
Sorry I forgot to mention the engine type. SBC350 with AD OEM style aluminum rad.
I will look at the napa part numbers. Thank you to everyone for the great information. |
I want to say thanks to the people who responded to my post. I first tried the Napa 7648 but the 1.75" neck was to long off the water pump. Then I tried the 7344 and it was just right. Just had to trim a couple inches off the 1.5" end and it fits perfect.
that's great.
for others who just can't find a match, I suggest using a piece of muffler pipe or the like, bent to fit the area, then have the exhaust shop swage one end a bit bigger to fit the larger size hose. install with short pieces of hose at each end. the bonus is that the pipe can have a tab welded on if it is a long run and then it can be supported-flexibly of course to allow engine movement under torque up. smooth the cut ends and use good quality hose clamps. it's only gotta hold 16 psi. |
![]() Join Date: Jul 2007
We need to put that hose number down in the things to remember list because someone else will be looking for it before long.
That's weird; all the OEM style aftermarket aluminum radiators I've seen have had 1-3/4" bottom hose size. I didn't even know they were available with 1-1/2 lower outlet. Mine:
1951 Chevy Panel Truck |
I thought it was a OEM style rad. I'm not sure because I bought the project partially completed.
Here is another picture for reference. I assumed it was OEM style because it fits between the rad support and blots into the factory OEM mounting holes. It also has built in trans cooler line hookups on the bottom. It also has a flex-a-lite syclone fan on the front and I've added a painless wiring fan relay as well. |
