Old 09-19-2018, 10:46 AM   #1
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
1997 engine
I have 1997 Tahoe engine in my truck. what gap do I use for it.. I changed the intake to adapt a carb and I have a regular HEI. 1406 carb..
Sick5 is offline   Reply With Quote
Old 09-19-2018, 11:31 AM   #2
PGSigns
PGSigns's Avatar
Re: 1997 engine
Gap em at 40 and see how they look after a 1000 miles. Plug will tell you if they are good.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 09-19-2018, 11:42 AM   #3
Sick5
C10 CLUB Y QUE!
Sick5's Avatar
Re: 1997 engine
that's what I gap them now but I read they originally gap for 60.
Here is the issue im having
as my torq convertor locks up its start to shake bad and sound like im running on 6 cylinders I give hit the gas and it shakes even worse bogs a bit but it feels like I have no power.. I change wires and plugs so far. im thinking about changing the dizzy and see if that helps
Old 09-19-2018, 12:27 PM   #4
'65 chevy lover
Re: 1997 engine
I don't know what you are talking about when you say you are thinking about changing the 'dizzy'. Did this suddenly start or progressively get worse? Did you look at the distributor cap? It could be that. At least have a look at it. I hope you find out what the deal is.
'65 chevy lover is offline   Reply With Quote
Old 09-19-2018, 03:34 PM   #5
geezer#99
geezer#99's Avatar
Re: 1997 engine
Could be two things.
Lack of timing and/or too much fuel pressure.
Old 09-19-2018, 11:48 PM   #6
Captainfab
60-66 Nut
Re: 1997 engine
Did you install the melonized gear on your distributor? Are you running a stock coil? What is your timing set at?
