![]() Join Date: Jul 2016
antenna wire routing?
On a factory radio install, where does the antenna wire enter the cab?
My '65 suburban didn't come with a radio. years ago i put one in and just hacked a hole under the cowl extension, right where water runs down from the cowl vent,so even tho i sealed it with silicone and plumbers putty it still leaks.
1965 Suburban, 2 wd.,292, 4-speed. proudly owned and operated since Valentines day 1969. |
But Found Her 25yrs Later!
Re: antenna wire routing?
Here's another good thread :
http://67-72chevytrucks.com/vboard/s...hlight=Antenna
Thank You, i was only 7 inches too low, and in front of the vent. now after 40 years i can finally get the cable out of sight.
