Old 10-06-2018, 01:07 PM   #1
Mryan
Active Member
No dash lights (advice)
I lost dash lights a week ago and am trying to track down the problem. I changed the headlight switch and still have none. When I check for power at the fuse box I don't have power at the fuse. My next step I think is to check behind the fuse block for any open circuit. Am I on the right track?
Mryan is offline   Reply With Quote
Old 10-06-2018, 03:35 PM   #2
Mryan
Active Member
Re: No dash lights (advice)
Found the trouble, the green wire in the headlight switch cluster had backed out and was not making good connection. Happy now...
Old 10-07-2018, 09:21 AM   #3
Mike C
Mike C's Avatar
Nice easy fix. Another common loss of dash lights is when the rheostat fails in the headlight switch. But that’s not near as cheap as your fix!
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 10-07-2018, 05:36 PM   #4
LockDoc
The Older Generation
LockDoc's Avatar
Thanks for the followup. That will help someone else down the road....
LockDoc
Leon
Old 10-08-2018, 04:36 AM   #5
'68OrangeSunshine
'68OrangeSunshine's Avatar
I once cured that on a new-to-me '71 Jimmy by replacing every single peanut bulb in the dash cluster. Also had to reconnect the speedo cable because the PO didn't care how fast he went.
'68OrangeSunshine is online now   Reply With Quote
