![]() Join Date: Jun 2017
big block 402 engine brackets
Just bought a 402 for my 69 truck don't remember mounting bracket location and engine came with some of them this one has alternator on passenger side i dont think thats right maybe it is
need photos or help so i know what to buy thanks |
Re: big block 402 engine brackets
The truck pulleys and mounting brackets are the same as the 65-68 big block Chevelles if you are looking for a source for replacements.
But you are correct, passenger side alternator setup was for the long water pump that was never installed on 68-72 big block trucks. Sounds like somebody swapped a big block into your truck from a 73 and up truck donor or 69 and up car donor.
need pictures of ac brackets have the other figured out
Google images for 68 Chevelle ac brackets should find it.
![]() Join Date: Nov 2013
this is a pic taken from another member...they are the stock 72 ac brackets
and the ps and alt brackets
one more
ps brackets
yes
#12 | |
It’s mounted to the driver side fender.
#15 |
Those are mine which would make them '70 but I imagine all the same!
1970 GMC Sierra Grande Custom Camper - Built, not Bought 1969 Pontiac 2+2 427/390 4-speed Coupe 1969 Pontiac 2+2 427/390 4-speed Convertible |
#16 |
![]() ![]() Join Date: Feb 2009
From a dry run I did. Shows all the brackets. It doesn't show the retainers/clamps near the evap. I have assembly instructions if you need it, down to the bolt type.
Tony 71 Custom Deluxe, SWB, 2WD, 402, A/C. I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025 |
#17 |
#18 |
Found a thread using search box at top of page with check box for this site selected. There are some included that had a bracket from radiator support, but the big block trucks I have owned (70 and 71)have had it like on fender.
http://67-72chevytrucks.com/vboard/s...d.php?t=735249
