65Custom Build Thread
Hey guys I have been a member of this site for awhile but not a participating member. So I figure it is about time I started my build thread since I see so many of the guys around me have build threads I figure I should add mine maybe I can add some what not to do's or maybe a to do, I do sometimes hit on something that is good.
I have a 1965 Custom C10 I bought it just outside of Nashvegas in 2007. I have a ton of pictures. I try to take pics of everything that I do some for memory so I can put it back together and others to show what I have done. The project plan is to do a Resto-Mod as some call it I'm trying to just do some good updates and some custom touches too just want to be a little different in a subtle way Keep the look of the truck mostly original looking but with some things that may make you to ask question. 1. Plans are to put a LS1 and 460le for power 2. I have a locker for the rear & convert it to 5 lug front and rear with a 3:42 gear 3. power 4 wheel disc 4. close ratio power steering 5. front and rear sway bars 6. AC, power windows & locks, tilt wheel, once piece windows (not sure about this one I go back and fourth on it) 7. relocate the gas tank to under the bed 8. Some other custom touches that you will see as I go along ( I hope ) These pics are just after I got her home and started tearing her down. I have the frame ready to go back together and I am currently working on the cab metal work So there has been a lot of work on her (no name yet) much more than anticipated, but this one is being saved although it probably should have scrapped, it looked ok while it had all the paint, bondo & floor repair cover up goo on it I have plenty more pics to post since I have made a lot of progress in three years just to get y'all up to speed on where I am currently at unless y'all want to just flash forward Sorry for long post but this is the initial post Last edited by 65Custom; 10-18-2009 at 11:23 PM. |
meowMEOWmeowMEOW
Re: 65Custom Build Thread
sounds like you have big plans, but your def getting started. Those floors looks scary tho.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING ![]() |
1 thing at a time is progress.
![]() I've talked to you several times on the phone, I need to make it a point to stop by and check you out.
Alan
Philippians 2:14-16 |
#4 | |
We started out builds close to the same time but dang you are much faster than I am about getting things going any way maybe we can meet sometime soon i just have to get off my butt and get up there |
So I'm getting used to this forum so bear with me if I make any slip ups I'm sure you guys will guide me along
Oh yeah I'm bagging my baby Had a friend talk me into it Somebody may need to tell me how to quote the pics Last edited by 65Custom; 10-18-2009 at 11:40 PM. |
A few more shots
Creating templates for boxing in the frame, straightened the rear brace, the rear trialling arms we splitting apart and I found a website where they sell used nascar parts and bought some trailing arms they fit prefect with a little bit of work. Also filled a lot of the holes in the frame for a much smoother look. Last edited by 65Custom; 10-18-2009 at 11:45 PM. |
Hope that all these pics does not cause a problem loading them all at once
Yes it was pretty once I got back from the blaster that is a lot of sarcasm in there I guess I'm a glutton for punishment |
I can't show all the pics here but I'll do my best to get yall caught up
and sorry if there seems to be some jumping around just trying to get some of the highlights Got the frame back from being powder coated and storing at a friends house Got the cab back from the blaster too Got a donor cab this one the floor was good but the upper half was rotted so I couldn't just swap them out but it is working out well going to route Im taking even though it seems to be a long road around this rust mountain Donor Floor before it went to the blast and after I have finished fixing all the Rust it turned out well Last edited by 65Custom; 10-18-2009 at 11:44 PM. |
Ok maybe I can get yall caught up on this post or the next one
replaced the A & B post bottoms on both sides cut the firewall out it had a bunch of holes that didn't come from the factory yep I had to build the whole lip around the firewall from the floor up really from the bottom of the A post up and around Finished shot of the mounting flange for the firewall yep even the windshield washer mounting had holes in it so I replaced the whole thing |
Ok maybe this I can get yall caught up
if you want to see more pics here is my website where I'm trying to chronicle as much as I can http://home.comcast.net/~remock/ Separating the cab from the floor Rolling the new floor into place Setting the cab back down on the floor welding everything back together after checking for square believe it or not it is near perfect rebuilt the cowl drip rails to keep the water out of the interior |
Resistance is Futile
WOW! Ton of metal work....it will be nice when its all together; nice job!
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
ok I think this one catch most if it up to date
Well almost I have some new pics to take and will post those soon Working on replacing the bad metal on the back wall Fitting the rockers I have them welded in place now they look great and the door gaps are near perfect. I am planning on re-skinning the doors since mine are full of bondo, I have the 2/3's of the cowl welded back on and should have it completed by the end of this week and hopefully will have the cab corners on by then too and the back wall welded in place. Once I have all that done I am moving to the roof panel got a panel from greg65 that is way better than what is on mine Once I have all this done I think that I can truly say this this is one rust free cab it should be good for another 40 plus years I hope since I have been trying to don extra things for rust protection that was not done when they originally put these things together. talk to y'all soon!! Last edited by 65Custom; 10-18-2009 at 11:42 PM. |
Thanks man I think I am slowly beginning to get good at it although I'm not fast. I think that is due to me being a perfectionist but knowing that I'm not able to make it perfect but basically making sure that I'm doing it right even if it takes me longer My dad had one of these trucks when I was a kid and I fell in love with it, it will be my luck that once I get it finished my son will want it and Ill have to start another one any it will be fun
OK these bring everyone up to date as to where I'm at in the build I know that this is not all that exciting but it has been almost three years of work so far. Maybe i can be of some inspiration for someone who has one that seems like it may be too far gone so you can see it is possible to save one. and yes I may be a little crazy for trying to keep this one alive.
door gaps are really good and the doors decent but will be reworked I think I will reskin them since going that route is a bit cheaper than new shells Last edited by 65Custom; 10-18-2009 at 11:47 PM. |
#15 |
60-66 Nut
WOW! you've done some serious metal work on that cab. I'm impressed with the results. Keep up the excellent work. I'm looking forward to updates.
#16 |
What did you decide to do with the bed you bought out of Texas?
1965 c-10 swb 1997 c-1500 extended cab 2004 tahoe 1993 mustang gt BUILD THREAD:http://67-72chevytrucks.com/vboard/s...d.php?t=336653 |
#17 |
283 Drama Queen
![]() Join Date: Dec 2004
![]() Please keep us posted, step by step - lots of excellent information! Mac. ![]()
For about 12 years of my adult life I had a severe speech impediment. My ex-wife never let me get a word in edgewise. |
#18 |
![]() Join Date: Mar 2008
Wow, awesome work! that is definitely a lot of sheetmetal work. Welcome and keep us posted we are such picture monsters lol
1964 Fleetside LWB 1995 Yellow Mustang convertible 1996 Camaro Z28 My build thread Looking for help on completing the Disc Brake Upgrade Reference Thread If you didn't build it, you don't really own it |
#19 |
That is awsome. After seein the rusted floor in the begining, I was ready to write this one off as another project that will never see the light of day. But replacing the whole floor??? that is frikin awsome. I love it.
#20 | |||
![]() Quote:
I decided to keep it I think it is very fixable with parts from the other one Quote:
Yeah man I wish they had actually made a replacement floor for ours like the do the 67-72 but it has been a great learning experience and not as hard as one might think |
#21 |
I decided to go ahead and get new skins for my doors since the skin cost is considerably less than one new door shell and I got nothing but time on my hands to fixmy
doors. Since I tried to find some good doors but everything I come accross is worse than what I have. The parts came in today and DS panel is bent in the top corner by the mirror mounting holes I will probably be call them them tomorrow about that one. I also bought new cab corners since I was having issues with getting them to fit right without a lot of cursing and other things flying across the garage and after talking to Alan about his and what he ended up doing I decided to get new ones. I searched all the suppliers and settled on one that i thought might be the correct ones. I got the new cab corners too and man what a difference. I don't want to hammer on any of the suppliers out there but I cant believe they get away with what they are selling. Some of you out there may have already experienced this but attached are pictures of the first ones I bought sitting next to the new ones and you can really see the difference. If anyone is about to do this you may want to re think the parts you have. The new ones have the correct shape to the B Post also at the bottom where they meet the rocker it also has a more correct pinch weld on the back wall, it is amazing how much better these are in just the shape etc. I fitted the the passenger side today and it look pretty good to me, these fit like a charm and look correct and were much easier to get fitted. As soon as I can post pics again I will put them up |
#22 |
Sunburst C10!!!
awesome build
Gage 1967 C10 Shortbed Stepside |
#23 |
Alright here are the pics of the cab corners if anyone wants to know where they came from just send me a pm.
#24 |
One foot in front of the other
![]() Join Date: Aug 2008
Way cool
#25 |
Member of the longbed union.
man looks like you've been doing a lot of work.
Paul 88 GMC Crew Cab dually, 454/T400 64 LWB 400 HP 350/350T Bagged, under construction! Sold most of it! 92 S10 Iron Duke 5 speed, 5/7 drop for now. soon to be bagged. Sold http://67-72chevytrucks.com/vboard/s...59#post4637759 |
