Old 12-22-2018, 09:40 AM   #1
Ehud
What 4 speed do I have? 1969 c20
I am doing a ls swap and thinking about using this transmission. Which tranny do I have? Any input would help. My engine is all stock. And looking to get it on the road. I have this c20 4 speed that I belive to be good.
Thanks.
Ehud is offline   Reply With Quote
Old 12-22-2018, 02:54 PM   #2
57taskforce
All about them K’s
57taskforce's Avatar
Re: What 4 speed do I have? 1969 c20
Looks like an sm465 to me.
Tyler
Old 12-22-2018, 03:52 PM   #3
B. W.
B. W.'s Avatar
Ditto, 465
B. W. is offline   Reply With Quote
Old 12-22-2018, 07:41 PM   #4
Ehud
Thanks folks
Old 12-22-2018, 09:14 PM   #5
Mike C
Mike C's Avatar
How long has it been sitting like that? The shift tower is open to any rain and snow that chooses to fall on it. Even odds are it will be full of water.
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
Old 12-23-2018, 10:23 AM   #6
Ehud
It’s all good. No moisture. From what I have gathered this transmission has a extremely low first gear. Does this sound correct?
Old 12-23-2018, 10:24 AM   #7
toms68cst
toms68cst's Avatar
YUP! AKA Granny gear.
Unrestored 68 C-10 CST. Original 327. 4-Speed CH465. 50k or so miles.
TREASURER, Drum Brake Club.
toms68cst is offline   Reply With Quote
Old 12-23-2018, 08:46 PM   #8
Mike C
Mike C's Avatar
What are your goals for the truck? How are you configuring your swap motor? The SM465 is an awesome trans for a working truck. The deep first gear makes offroading and towing possible with moderate gear ratios.
But if you are looking to build a hotrod type street machine, the SM465 is the wrong transmission.
I ran a big cammed 327 in my Jimmy and the torque characteristics were completely wrong for the gear split on the 465. With the 210@.050 cam that is in it now, it works great.
44 Willys MB
52 M38A1
64 Corvette Coupe
Old 12-24-2018, 10:23 AM   #9
jocko
jocko's Avatar
Granny is 6.55:1. You won't use it unless farming or rock crawling. And that's ok, just something to be aware of.
Old 12-24-2018, 01:40 PM   #10
Quikshft
Quikshft's Avatar
My 4x4 has 3.07 differential gears and 33 inch tires and 1st gear even with that set up is pretty much un-needed on the street. You'll be left with essentially a three-speed. As somebody else mentioned it is a fine transmission for a working truck, I tow a 4,500 pound travel trailer and will use 1st to get things moving.
Quikshft is offline   Reply With Quote
