84 C10 Duel Tank LS?
Is there anyway to run duel tanks with an LS swap? Was thinking of running a external fuel pump after the fuel tank selector valve & running the supply/return line to the valve. I would use AN fittings to the rails, but the valve is plastic & could only use rubber lines. Would this work?
https://www.summitracing.com/parts/fif-40005 I have an 1984 C10 with duel 16 gallon tanks & with 3 port sending unit. Donor truck is an 2000 5.3 Silverado.
---1964 C-10 ![]() ---1966 C-10--350 V8-4 Spd-BBW-Short Bed- SOLD! ---1964 C-10 :283 V8 -BBW Long Bed |
![]() ![]() Join Date: May 2015
Re: 84 C10 Duel Tank LS?
I know it's been done
I didnt research the pump you have listed but you'll need 55-60 or so lbs of fuel pressure The suction side is low pressure...I used fuel hose and clamps If the return is unrestricted it can be low pressure...not sure how it would work through the sell tor valve
Mongo...aka Greg RIP Dad RIP Jesse 1981 C30 LQ9 NV4500..http://67-72chevytrucks.com/vboard/s...d.php?t=753598 Mongos AD- LS3 TR6060...http://67-72chevytrucks.com/vboard/s...34#post8522334 Columbus..the 1957 IH 4x4...http://67-72chevytrucks.com/vboard/s...63#post8082563 2023 Chevy Z71..daily driver Last edited by mongocanfly; 01-08-2019 at 06:15 PM. |
