Old 02-21-2019, 07:32 PM   #1
txbill
1980 c 10 rear suspension
can trailing arm suspension be installed on a 1980 c 10
txbill is offline   Reply With Quote
Old 02-22-2019, 12:37 AM   #2
jbristo67
resident oilfield trash
jbristo67's Avatar
Re: 1980 c 10 rear suspension
Don’t know why not
1967 SWB C10 396/400 factory air
factory tach (sadly had to send to a new home)
1986 Honda 70 Fourtrax
1991 Chevrolet K5 blazer 2wd
1982 Mastercraft Pro Star 190 Stars and Stripes
2002 Chevrolet Tahoe
2011 Nissan Armada
jbristo67 is offline   Reply With Quote
Old 02-22-2019, 08:12 AM   #3
It's probably a lot of work and you might be better doing an aftermarket 4 link setup
Old 02-22-2019, 09:30 AM   #4
Mattchu60
If it is a short box - YES, Long box - No.
I am currently doing this - CPP sells a Trailing Arm kit for 73-87 which I am using. However be warned, this kit is poorly made - it has good "bones" to get you started but you'll need to make some modifications (cutting some of the steel parts and re-welding them).
I called them with my problems and they offered no solutions, just the typical - "thats the way its made." After that I would not recommend their parts to anyone - they do not stand behind them at all.
Mattchu60 is offline   Reply With Quote
Old 02-22-2019, 02:00 PM   #5
808_67C10
808_67C10's Avatar
If it is a short box, are you looking to go trailing arms with springs like the 67-72 style or the same with bags? Just saying because, if you are wanting to bag the truck, you can do a basic 2 link from Extensive Metal Works located right there in your backyard... it is "similar" to trailing arms and doesn't require a lot of modifications. Bolts into the front leaf spring pockets... you don't have to go with the full bridge either... just a c-notch.
https://store.ekstensive.com/collect...suspension-kit
They sell it without the bridge and with notches.... I suggest calling because they are horrible at answering emails or chats (in their website).
Check out this build (3/4 down the page): he has the set up with c-notches... basic and clean
http://67-72chevytrucks.com/vboard/s...ensive&page=14
Frank (Hilo, Hawaii)
Trucks, Tacos, and Beer go together like Peanut Butter and Ladies!
85 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=760383
67 C/10 SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=489298
79 K5 Blazer SOLD http://67-72chevytrucks.com/vboard/s...d.php?t=657461
808_67C10 is offline   Reply With Quote
Old 02-22-2019, 04:19 PM   #6
Loco83
Loco83's Avatar
Porterbuilt had or has a trailing arm kit, heard they discontinued it.
http://67-72chevytrucks.com/vboard/s...d.php?t=549029
Loco83 is offline   Reply With Quote
Old 02-22-2019, 05:16 PM   #7
Loco83
Loco83's Avatar
CPP kit,
https://www.hotrod.com/articles/1979...trailing-arms/
