Closed Thread
Old 01-24-2019, 05:06 PM   #1
GTS61
Heck of a time with my truck
I was driving home this morning from work with my lights on when I noticed that the voltage meter was ready 10, it was over 12 when I left work. I was almost home and the truck started to stall on and off and the lights went dim and the volt meter was almost 0 then my truck quit. My wife had to come and boost me and I still only got a block down the road and the engine quit again so I left it there until I got some sleep. It must be my generator but I don’t know enough about engines. And advise would be greatly appreciated. Thanks Greg
GTS61 is offline
Old 01-24-2019, 05:14 PM   #2
CANUCIT
CANUCIT's Avatar
Re: Heck of a time with my truck
Charge the battery and start the truck , disconnect the battery cable while its running
If it dies your alternator is shot
If it still runs check your cables and connections
1962 chevy short and wide
2015 z71
1967 SS Chevelle
CANUCIT is offline
Old 01-24-2019, 05:20 PM   #3
GTS61
Thanks for such a quick response!!
GTS61 is offline
Old 01-25-2019, 10:27 AM   #4
jchav62
1962 C-10
jchav62's Avatar
That test always works for me, if you do not have a volt meter handy. Has for years.
My guess is that your voltage regulator went out. If not that, the gen/alt. What year is your truck?
Joseph Chavez
"See the USA in a Chevrolet!!"
......................_____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
1962 C10 Shortbed Fleetside 327/th350 GV overdrive
1974 C10 Longbed Fleetside 350/th350 "The Trash Truck"
1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4
2015 GMC Sierra SLE 1500 4x4
jchav62 is offline
Old 01-25-2019, 03:56 PM   #5
Clyde65
Clyde65's Avatar
I would take the battery to an auto Parts house and have it tested. Sounds like it has a dead cell in it. Where I live, batteries only last about 3 years tops. Good luck!
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline
Old 01-25-2019, 04:14 PM   #6
61K10
61K10's Avatar
he said his volt meter was 0 a volt gauge or an amp meter? 0 means no charging.
1961 chevy K10
my build is------------61K10 build
61K10 is offline
Old 01-25-2019, 04:43 PM   #7
GTS61
It’s a volt gauge. It is a brand new battery also but could still be a bad new one I guess.
GTS61 is offline
Old 01-25-2019, 08:53 PM   #8
shp4man
shp4man's Avatar
So recharge the battery. Hook the voltmeter to + and - on the battery. Should read about 12.3 volts. Now, start up the truck. Run it up to about 1500 RPM. Voltmeter should read about 13.5 volts. Up to 1.5 volts more is OK.
Now, turn the lights on bright and the heater fan at full speed. Run it back up to 1500 RPM. Does the voltmeter read the same or less than the 12.3 or whatever you got with the truck not running?
If yes, there's a problem in the charging system.
Everybody has to believe in something. I believe I'll have another beer.
shp4man is offline
Old 01-26-2019, 10:46 AM   #9
GTS61
Thanks a lot. I’ll get that after work today. I appreciate the help. Right now I’m thinking it’s my generator.
GTS61 is offline
Old 01-26-2019, 12:32 PM   #10
TJ's Chevy
TJ's Chevy's Avatar
Voltage regulators are cheap so I'd start with one of those after doing some testing.
TJ's Chevy is offline
Old 01-26-2019, 08:13 PM   #11
GTS61
Missed it. Found my problem anyways. Bad wire is all it was. Thanks for the help everyone!! I learned about a lot of trouble shooting ideas. Love this forum
GTS61 is offline
Closed Thread
