Is there any way to tell the whole vin from just a frame? I traded an old engine for supposedly a 65 c10 parts truck but onky have the frame. The vin on the frame starts with 5 but I'm wondering if it's a C20.
Had a hard time searching for this on the forum, my apologies if it's been answered already. Thanks!
1965 C10 Longbed Stepside 1969 Chevelle Malibu 1962 C20 Fleetside - Build Thread (Sold before I could finish) |
![]() Join Date: Aug 2008
Re: Frame Vin
is it a longbox frame ? all shortboxes are 1/2 ton, any other parts on it ?
It's a long box, believe it was a fleet side. Took a few pics of the frame since I was comparing the suspension.
(Can only seem to upload one on my phone)
![]() Join Date: Mar 2015
Re: Frame Vin
It is most likely a GMC frame because of the leaf springs but GMC's did not have vins on the frame.
Current projects: 1966 Chevy Custom PS PB A/C BBW 283 v8 3 speed OD 1966 GMC Long Step 1966 GMC 3/4 ton Custom PS PB Sport trim 351 v6 1966 GMC 3/4 ton 4x4 Custom PB 305 v6 np435 1960 GMC Custom 1968 GMC 3/4 ton 4x4 Short Bed 1962 K20 Tow truck 1961 GMC Extended Suburban Panel and a few more |
Re: Frame Vin
yep it is a gmc frame
Re: Frame Vin
Any difference in the frame design? They look about the same though I haven't measured them yet though.
60-66 Nut
Re: Frame Vin
The '63-'66 chevy and '63-'66 GMC frames are basically the same and are interchangeable. The main difference is the leaf springs on the GMC. That and the lack of a VIN on the frame as Classic v6 GMC's said.
Re: Frame Vin
It definitely has a frame stamp so I'm going to assume its a 65 chevy frame with gmc suspension
1961 crewcab
Re: Frame Vin
all you can tell from the frame vin, is the year, assembly plant, and serial #
http://67-72chevytrucks.com/vboard/s...d.php?t=316902
60 build: http://67-72chevytrucks.com/vboard/s...d.php?t=280904 61 crew build: http://67-72chevytrucks.com/vboard/s...d.php?t=646830 63 build: http://67-72chevytrucks.com/vboard/s...d.php?t=336537 64 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=448681 65 'burb build: http://67-72chevytrucks.com/vboard/s...d.php?t=590715 65 build: http://67-72chevytrucks.com/vboard/s...d.php?t=281955 |
Re: Frame Vin
If I'm not mistaken, don't the k10s have leaf springs. Mine 1964 chevy k10 has leaf springs on the rear. so yours may be a 4x4
1964 Chevy Factory K10 Short Bed Mitchell Sampson |
Re: Frame Vin
Heavy Duty suspension option on a Chevy was leaf springs.
-Brad
'61 Suburban daily driver: off the road due to 180-pound 8-pt buck! '62 K-10 long-step project '61 C30 Camper, aka "Valdez" There's no cool like Old School |
Re: Frame Vin
My 65 Chev C20 has leaf springs on it.
However I don't believe that it has that red bar from frame to springs above the axel. Do GMC's have that red Bar ? |
Re: Frame Vin
"Do GMC's have that red Bar ? " NO that is an add-on torque bar
also from OP.... yes it was a step side from what can be seen of the rear bumper And yes K10s had leafs front and rear (we cant see the front here) But the rear spring hangers are NOT low enough to be 4X4 |
Re: Frame Vin
I hav my frame numbers would like to know what year it is chevy frame 2z513193 some idea would be great
Posted via Mobile Device |
#15 |
1966 Crew Cab & 4X4 Fanatic
Re: Frame Vin
Tags |
frame, vin |
