TH 700R4 TCC lockup wiring
First I have a 1986 GMC that came original with a 700R4, and a previous owner swapped it out for a SM465, I'm going back to a 700R4.
My wiring question is the 700R4 I picked up is from a 1989 Chevy 2500, it has a 3 wire plug for the lockup circuit, one of which goes to the ECM. My 1986 doesn't have an ecm connection for it. What is this 3rd wire for and is it really necessary, and is there a way to bypass it if it is? Attached is the schematic for the 1986 circuit, and the 1989 circuit. |
Re: TH 700R4 TCC lockup wiring
My 85 has a 3 wire hookup, one of the wires went to the egr solinoid for some reason, and my transmission works as it should without that hooked to anything. I'm not sure the wiring on a 85 and 86 is the same though. Is the harness for the 700r4 still in your truck? I'm not sure if it's the same for 86, but the 85 set up is pretty basic with a low vacuum switch, and a brake switch to control the lock up.
77 k10 winter beater build http://67-72chevytrucks.com/vboard/s...d.php?t=716884 85 GMC short fleet budget build http://67-72chevytrucks.com/vboard/s...d.php?t=714222 80 C10 stepside build http://67-72chevytrucks.com/vboard/s...d.php?t=693848 |
#3 | |
The 1989 diagram on the right shows 2 different wires coming from the ECM and one from the brake switch. This is where I'm confused. I was hoping Hatzie would hop on and provide some input knowing how good he is with wiring problems. |
Moderator
![]() Join Date: Oct 2008
It should work just fine without terminal D connected. Terminal D is a slightly different diagnostic tap for the ALDL port and the ECM in 89 and an EGR bleed solenoid on some earlier rigs. IIRC the ECM controls EGR bleed on the TBI rigs.
Whoever did those 82-86 wiring diagrams at GM should be hung, drawn, and quartered... They didn't label the transmission side connector with terminal letters and they show wire side on both so it's easy to mis-read the two terminal diagrams. You have to mentally think about where things would be if you plugged the connectors together. If you look at one of the diagrams with EGR purge and three terminals it becomes clearer what's happening. The 89 transmission should have an additional thermal switch in the internal TCC circuit but that won't affect the external wiring. You should find and install a Low Vacuum Switch. The Low Vacuum Switch cuts power to the TCC when manifold vacuum drops from the throttle opening. It's an analog lockup control so you don't burn up the TCC by applying torque without cutting out the clutch. You definitely need it to utilize the TCC without damaging it. Make sure the brake pedal switch has the TCC switch contacts as well... The standard transmission brake pedal switch doesn't have provision for this.
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. Last edited by hatzie; 02-19-2019 at 10:53 AM. |
#5 | |
#6 | |
Moderator
C is unused... D is the EGR ECM terminal. Your harness doesn't have a wire in C or D. That doesn't matter. The picture is not needed. I have the uncompressed scans and a 50" 4K monitor.
And please let us know if and how your repairs were successful. |
So the brake switch and the low. vac. switch unlock the tcc but what locks it?
To explain how it works, the brake switch, and low vac switch cut the power to the lock up solenoid inside the pan. Now a detailed description. In the trans there are 2 or 3 pressure switches and a solenoid. Power flows from the fuse panel, through the brake switch, then through the low vac switch and into the trans. If you throttle hard on the motor it's vacuum signal will decrease for for a brief time, causing the low vac switch to break the circuit and cut power to the lock up circuit until one of the switches inside the trans detects pressure in the 4th gear oil circuit. The brake switch works in a similar way, during braking or panic braking it cuts the power circuit and unlocks the torque converter, and remains unlocked until the 4th gear pressure switch detects pressure again. These same connections on the brake light switch also double as a cut off signal for the factory cruise control if equipped.
