anyone use aftermarket 81-87 Grille Surround Trim?
Im about to put a large order for parts in at LMC - one item I am looking to buy is the thin trim that goes around the grille opening on the 81-87 trucks. the stuff i have is all bent up. Anyone used these trim pieces? I've had bad luck with aftermarket not fitting at all, I'm hoping these work ok.
Any opinions before I order? I can always go hunting in the junk yards for a set but not sure I would find much locally. |
Re: anyone use aftermarket 81-87 Grille Surround Trim?
This is the LMC set. Not near as thick as the originals.. The plastic clips "ghost" through the trim. The over-lap between the pieces is terrible. Overall, I'd rate them a 5 out of 10. Pretty much the only option if you need it. Not show quality, but good enough for a daily driver.
My museum of good intentions: 1957 3100 BBW restomod -- 1970 442 W30 |
MOTORHEAD!
I have the LMC stuff. It’s junk. As stated, 5 out of 10 rating.
82 GMC High Sierra VortecPro 496 12 Bolt, 3.42's AFR 265 Holley 850 Performer RPM Air Gap Hooker 2455's TCI Turbo 400 Super Street Fighter TRRC 12 Bolt Eaton Posi/3.42 Mark Williams Axles Cal-Tracs Hoosier 30x10.5 Radial Slick Ryan Brown Performance 850 Holley Full weight long box pickup Current best- 11.28@119mph |
Robert Olson Transport
![]() Join Date: Oct 2002
fully agree with above comments
Bob 1951 International running on a squarebody chassis "If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board" http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!) PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport Live each day to the fullest.. you never know when fate is going to pull the rug out from under you... I hate cancer!! |
Thanks for the replies - sounds like its not worth buying. I'll have to make a trip to the parts yard and see if I can assemble a set from there.
I had to massage mine to make it fit decent, but I purchased mine from classic industries.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11 1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020 67 GMC Stepside Straight six/3 on the tree "The Peach" 2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934 The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903 ![]() |
