Old 07-07-2019, 10:47 AM   #1
Slowguy
Ridetech or qa1 bagged
I’ve spent some money on this because I feel ride quality and handling is just as important as tons of power.
I am going with accuair cvt and elevel for simplicity. I have double bellow 2500 lb bags, installing shock relocators front and rear. Front and rear sway bars, cupped the front lower control arms, drop spindles, front disk with power hydraulic retrofit, front caster mod to bring the lower ca’s forward, adjustable rear panhard bar, relocated battery and tank to the back for a little better weight distribution, and every joint, bushing, bearing etc is brand new.
I’ve been reading a lot and I hate how expensive it is but with bags it seems an adjustable dampening Shock is a real benefit. I’ve only really seen qa1 and ridetech. I’m leaning toward ridetech but I’ve also seen where people have done coilovers from qa1. Isn’t that overkill? Why would you use bags and the springs on a coilovers? Makes no sense to me.
Slowguy is offline   Reply With Quote
