Old 03-26-2019, 06:18 PM   #1
71CHEVYSHORTBED402
71CHEVYSHORTBED402's Avatar
Water pump studs
Found on the parts book a stud was used to mount the water pump, generally placed on the top passenger side on most trucks. The 70-71 BBC takes two different studs, one is placed on the top driver's side as well.
What were these studs for?
I found mine with 3/8-16 x 1.3/4" bolts. They're stamped with a dog bone, which is era correct, but don't know why I'd have four if it had studs. 1.3/4" seems a little short as well, with a lock washer they're not even using 1/2" of a 1" hole. Not even that with the top alternator bracket mounted by the top driver's side bolt/stud.
http://www.gmpartswiki.com/getpage?pageid=21310
Tony
71 Custom Deluxe, SWB, 2WD, 402, A/C.
I developed an assembly guide (kit) for restoring this truck from the ground up, complete with details including full hardware descriptions. Much of the info. applies to all 67-72 GM. My build thread, with some info. about the assembly kit https://67-72chevytrucks.com/vboard/...d.php?t=730025
71CHEVYSHORTBED402 is offline   Reply With Quote
