Old 03-25-2019, 10:14 AM   #1
robertsjm711
robertsjm711's Avatar
Broken Crank Bolt!
2002 LS 5.3l
While installing a new oil pump I felt my stomach fall out my feet when the crank bolt snapped while installing the harmonic balancer. I was removing the bolt to measure how much more to go. I am ~1/16 from seated, and it broke at the end with multiple turns to get the bolt out after the break. At first I didn’t think it broke until I looked at the bolt. Couple questions...
1. Has anyone had this experience, and what did you do?
2. Can the bolt be removed without removing the crank at a machinist? Cost?
3. Can I remove the crank without removing heads/top end?
4. Harm with running it as is?
I just bought a rebuilt trans (still on the bench) so funds are limited more than usual, thoughts?
It was said that if you cut off one hydra head, two more grow back.
-Lernaean Hydra
Build Thread:
http://67-72chevytrucks.com/vboard/s...d.php?t=743246
robertsjm711 is offline   Reply With Quote
