Old 02-15-2018, 11:46 PM   #1
stexag
Engine height and output shaft angle
Guys, I am having an issue with the the angle my 5.3 is mounted on my truck.
I have a 68 C10 that I removed the 6 from and am installing a 5.3/4L60E combination. I swapped the front crossmember from an 80s truck for the disc brakes. Other components include:
CPP sheet metal engine stands, Dirty Dingo Sliding adapter plates, & Energy suspension 'low & wide' SBC engine mounts
For a transmission mount I used the Early Classic 63-72 Auto trans xmember
The engine sits incredibly steep. With the frame level and the transmission mount (energy suspension) sitting right on the X member it was about 8*. I shimmed the transmission up almost an inch to get it to 5* but it is pretty high. I haven't set the cab on yet but I suspect I will have clearance issues the way it is now because I already have a problem at the middle crossmember with the driveline. I have checked this angle on the back of the output shaft and on the front crank pulley and they agree. I have heard the CPP engine stands can leave the engine a little high but I am currently just 1/2" between the pan and the steering link. If I could get the engine down that 1/2" I think I'd really need to do the same in the rear - still maintaining my 5*.
Has anyone had similar issues or does anyone recognize where I may have mismatched some components that could have contributed to such a steep engine mount? thanks.
stexag is offline   Reply With Quote
Old 02-16-2018, 12:21 AM   #2
mongocanfly
mongocanfly's Avatar
Re: Engine height and output shaft angle
not knowing exactly how you have it setup (pics would help) I would put the cab back on and see where your at....keep in mind your driveline angle needs to match your rear diff angle...if you have -5 on the trans you need +5 on the rear...just keep them the same...but without the cab on its hard to say...
Mongo...aka Greg
RIP Dad
RIP Jesse
2023 Chevy Z71..daily driver
mongocanfly is online now   Reply With Quote
Old 02-16-2018, 09:32 AM   #3
stexag
I will take better pictures today. I have these on my phone now... the engine mount/Stand combo
Here’s my clearance at the oil pan/steering link. Not a lot to drop?
Posting from my phone - please excuse typos/bad code
Old 02-16-2018, 05:47 PM   #4
Ghost's68
Ghost's68's Avatar
Following this.... I also have the same mounting setup as you, DD sliders and CPP stands. I’ll be dropping the engine in on Sunday.
Ghost's68 is offline   Reply With Quote
Old 02-16-2018, 10:06 PM   #5
mongocanfly
hard to tell from pic but it doesn't look like you can go any lower...id put the cab back on before I made a decision...
Mongo...aka Greg
RIP Dad
RIP Jesse
Old 02-17-2018, 01:20 PM   #6
62chevy302
hillbilly
62chevy302's Avatar
Im having the same problem.
I have 78 c20 mounts and dirty dingo 73 up sliders. I have a pol transmission crossmember and my driveshaft yoke is almost touching it. Do i have my crossmember upside down?
Are my engine stands too high? My frame is sitting with the nose down and engine is still not level. Help
-1962 C-10
62chevy302 is offline   Reply With Quote
Old 02-19-2018, 03:51 PM   #7
Steve Cole
Post a good picture of your tranny crossmember so we can see what you have. That other pic is so close up, we can't tell what you are working with. Take a step back and post another one. Engine mounts too.
Steve Cole is offline   Reply With Quote
Old 02-19-2018, 06:03 PM   #8
62chevy302
hillbilly
62chevy302's Avatar
Ok this is the trans crossmember. Yoke is almost touching the crossmember. The crossmember wont go the otherway because it hits the tailshaft.
-1962 C-10
Old 02-19-2018, 06:16 PM   #9
62chevy302
hillbilly
62chevy302's Avatar
Here is my engine mounts and the second pic is angle gauge reading 7 degrees
-1962 C-10
Old 02-19-2018, 06:24 PM   #10
62chevy302
hillbilly
62chevy302's Avatar
Front view of engine. I moved clamshell to lower holes in stand. It helped some but 7 degrees is too much and need to do something about tranny crossmember
-1962 C-10
Old 02-21-2018, 05:16 PM   #11
StorminNorman
That mounting pad on the trans is fairly close to the output C/L. Kinda like a 4L80e. I wouldn't be surprised if you need a spacer under (over?) the mount.
Edit :
If that xmember is this unit :
https://www.performanceonline.com/19...n-Crossmember/
Which it says fits Turbo 350/400, then you definitely need some kind of spacer. TH 350/400 mounts are farther forward and lower on the trans than it appears yours is.
StorminNorman is offline   Reply With Quote
Old 02-21-2018, 07:53 PM   #12
62chevy302
hillbilly
62chevy302's Avatar
I bought that style of crossmember because it bolts to the top and bottom of the frame. I will shim up the rear of trans and report back.
-1962 C-10
Old 03-02-2018, 12:16 PM   #13
71Charlie10
subscribed
71Charlie10 is offline   Reply With Quote
Old 03-06-2018, 11:01 AM   #14
J3rm0ff
I used the same engine mounts as 62chevy302 and the stock transmission crossmember and mine is angled too much. I'm hoping spacing up the Trans will solve my issue. I read of a lot of people using the 73+ frame stands and clam shells with the dirty dingo sliders but didn't see anyone mention any angle issues.
J3rm0ff is offline   Reply With Quote
Old 02-24-2019, 08:18 PM   #15
62chevy302
hillbilly
62chevy302's Avatar
I moved the clamshells down to the 6 cyl holes on the stands and cut the transmission mount pad off and flipped it. I havent set the engine and transmission back down in there yet but hope to in a couple weeks to remeasure the angles.
-1962 C-10
Old 02-25-2019, 03:58 PM   #16
Steve Cole
Keep us posted when you remeasure the angles. I have a similar situation. '68 c10 (low hump) I used the 73 & up clam shell style mounts from ECE and their trans cross member as well, (it looks just like yours) My engine sits at 7* nose up with the frame level. I hate it. There is no room to shim up the transmission because it is almost hitting the pinch weld in the trans tunnel now.
I may have to go with different engine mounts but I'm now sure which ones will work.
Old 02-25-2019, 05:03 PM   #17
62chevy302
hillbilly
62chevy302's Avatar
Got any pics of the ece mounts?
-1962 C-10
Old 02-25-2019, 09:45 PM   #18
Steve Cole
https://www.earlyclassic.com/sites/d...?itok=BEYu-H7H
If this link doesn't work, just go to earlyclassic.com. They are on the home page.
Old 02-25-2019, 05:13 PM   #19
J3rm0ff
I ended up using the 73+ c10 frame stands and making my own engine side mounts and spacing up the trans until it was as close to possible to the cab and it’s at a reasonable angle now. The truck oil pan is about a quarter inch from the crossmember.
Old 03-02-2019, 01:56 PM   #20
Steve Cole
Hey Stexag, first of all, sorry your thread got hi-jacked!! I too have a steep engine angle and cannot get my tranny any higher without cutting the trans tunnel. You do not have much room to play with near your steering linkage either. I have almost 2 inches to go down in this area. I am thinking about going back to the factory perches and using adapter plates. You may need to do the same, I don't see how you could lower your motor much more with your current set up. Good luck and keep us posted what you end up doing!
Old 03-02-2019, 05:19 PM   #21
shifty
Questionable
shifty's Avatar
Steve reached out by PM and pulled me back to the board. Just thought I'd pop in and mention I had similar issues with my 68 C10/LS1 swap.
I ended up going with the ECE mounts and tranny xmember with a truck oil pan, truck oil pickup and dipstick on an LS1 out of a totalled WS6. Tranny was smacking the tranny tunnel on my cab and didn't quite fit how I wanted on the stock xmember nor at right angle. HAd to cut my short hump and go with the taller big block tranny hump.
If it helps, here's a link to my thread and all the crap I did to overcome fitment over at LS1tech, pay attention to posts #42-50 for tranny and tunnel problems:
https://ls1tech.com/forums/conversio...-stepside.html
I'd tossed together a bunch of links to other GenIII build threads over there where you might find similar fitment issues:
https://ls1tech.com/forums/conversio...ml#post3395546
Some pics in my LS1tech build thread are dead, I should probably go back over there and fix that eh? It's been a minute.
@62chevy302 that green Z71 in your pic up above is a twin to the '98 I bought last year.
If I've got anything up for grabs, it'll be here: 7-hole gauge cluster for a 67-72 p/u FREE (link)
I can't check the forum daily. If I don't reply to you within 24 hours, drop me a PM! I'm (hopefully) still alive and will reply faster to a PM.
shifty is offline   Reply With Quote
Old 03-02-2019, 06:24 PM   #22
shifty
Questionable
shifty's Avatar
Here's a bunch of pics in no specific order - there are a few directories for specific stuff I was doing. http://www.satellitehead.com/images/68chevy/ls1/
But this is ultimately what I ended up with - ECE crossmember, tinkered with flipping right-side up and upside down, that and ECE mounts solved my fitment issues with just enough space between front of engine and radiator/fans.
Old 03-03-2019, 03:19 PM   #23
Steve Cole
Thanks for all your help Shifty, you're a good dude!
I was thinking of trying to use these.....
https://www.ebay.com/itm/C10-LS-LSX-...QAAOSwyLlXoVrI
In conjunction with the ECE mounts, (frame side parts)you think it could work?
Old 03-03-2019, 03:31 PM   #24
62chevy302
hillbilly
62chevy302's Avatar
They look just like the dirty dingo without the ability to adjust any.
-1962 C-10
Old 03-03-2019, 10:16 PM   #25
shifty
Questionable
shifty's Avatar
Here's what I'd say:
Look at this picture and you'll see how the ECE top-half plates bolt to the block. It looks like the kit you're looking at on eBay allows you two different mounting options, about 2.5"-3" out from where the ECE mounts are, and another 0.5" out. (I see two sets of 4 holes about half to an inch apart). You should (key word "should") be able to use that top half of mount with the bottom half of the ECE mount.
That said, if you measure up and find pushing the whole block forward 2"-4" those may work for you. The two considerations I'd warn you about is to be conscious of how the block is centered over the wheels and make sure there's no risk of interference with the A/C compressor (if applicable) And steering gearbox.
Note the bolt holes on the ECE are perfectly centered over where it meets the mount. I assume you won't have any added vibration issues from having the bolt holes off-center on the eBay mount?
