1954 Chev 3100 Wheel Bearing Dust Caps
Hello all,
Both my front wheel bearing dust caps fell off and I'm trying to locate replacements for my stock 1954 Chev 3100. I found a set that looked like they would fit based upon measurements. When I received the dust caps, they are about 1/8" too small. Look at the attached picture. The packaging indicates 2.18" diameter, but the actual measurement is 2.08". I'm still working to get a resolution to this problem with the vendor. Still searching for wheel bearing dust caps. Portland swap meet will be my next attempt to find dust caps. I'm tempted to draw up my own and 3D print. Last edited by Darthintel; 02-20-2019 at 01:42 PM. Reason: added info |
Re: 1954 Chev 3100 Wheel Bearing Dust Caps
The wheel bearing dust cap saga continues.
I now have 4 sets of dust caps that indicate they are for a 1954 chev 3100 truck. All are too small. All hardware I've bought so far has fit correctly - wheel bearings, brakes, wheel cylinder. I have measured the ID of the hub and it's 2.13", which converts to 54.1mm. What could be wrong? I don't think the hubs are off anything different, but now starting to have doubts. Yes- they are 6 lug hubs. It would be great if some one with a 1954 chev 3100 could measure the ID of their hubs for comparison. Thanks |
Funny that I would see this, I just an hour ago ordered some from my local parts store for my truck. It's got passenger car hubs though so I am not sure if they are the same. I will be trying them out tonight or tomorrow and will let you know if they work and what the measurement is. I have a pair of originals too, but they are in pretty funky condition.
Brian
1948 Chevy pickup Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats! Bought with paper route money in 1973 when I was 15. "Fan of most anything that moves human beings" |
#4 | |
![]() Join Date: Sep 2011
#5 | |
Brian
strange you are having problems. I got my dust covers from NAPA. they are for a passenger car hub and fit great. I took the hub & drum with me and they measured them on the spot. had 2 in stock.
I have been to Napa and looked at everything they had on the shelf. Nothing even close.
#8 | |
It has drums right? Brian
#9 | |
What else could it be? |
Who knows, this is odd.
Brian
#12 | |
Brian
First 3D print ....
#15 |
#16 |
The whole concept is so friggin wild it's crazy! What material is it made from?
Brian
#17 |
ABS
ABS or Acrylonitrile butadiene styrene is a common thermoplastic polymer typically used for injection molding applications. This engineering plastic is popular due to its low production cost and the ease with which the material is machined by plastic manufacturers. Better yet, its natural benefits of affordability and machinability do not hinder the ABS material’s desired properties: Impact Resistance Structural Strength and Stiffness Chemical Resistance Excellent High and Low Temperature Performance Great Electrical Insulation Properties Easy to Paint and Glue |
#18 |
so make the damn things out of abs & start selling them !!
#19 |
Took the under sized dust caps to a muffler shop and had them stretched.
Now to buy the new rims and hub caps to fit. Looking at buying the Wheel Vintiques Series 12 smoothie and hub caps. Wheel https://www.wheelvintiques.com/acces...ap-47-198.html SKU 12-660604 16x 6 , 6 lug 5.5" bolt circle, 4" backspace Chevy Hub Caps SKU 2030A I'm curious if anyone has used these on a stock 1954 Chev 3100. |
#20 |
That's my kind of solution: simple, inexpensive and effective. Make it work, get 'er done.
1951 Chevy Panel Truck |
