Old 06-05-2019, 05:23 AM   #1
Ganty101
Looking into getting 5 stud hubs on the rear!
So currently my 69 c10 has 5studs on the front hubs and 6 on the back. For obvious reasons I’d like to match em all up so either all 5 or all 6. Now I’ve seen some rally style alloys on summit and they are 5-stud which make me lean towards 5 but please guys let me know what my options are. Am I best off getting a conversion kit for the rear drums to put discs in? What info do you need to give me good advice? I know that I have a 411 ratio rear axle option number 4ho4dr.
Ganty101 is offline   Reply With Quote
Old 06-05-2019, 06:30 AM   #2
bigmac73
bigmac73's Avatar
Re: Looking into getting 5 stud hubs on the rear!
you are going to have to swap axles to a 1971 or higher rear end or swap out the whole differential. personally I would call Randy;s Ring and pinion and tell them your issues and let them help you out.
Sounds like some one has already upgraded or changed out the front spindles and brake rotors up front.
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 06-05-2019, 06:33 AM   #3
Ganty101
So maybe swap out the fronts to 6stud? Could be cheaper to do overall. I’d rather keep the original rear axle to be honest. I thought if I could just get a pair of shafts to bob in I’d be ok but a new axle is more than I’m wanting to do to it!
Old 06-05-2019, 06:40 AM   #4
bigmac73
bigmac73's Avatar
you might be able to swap out the axle shafts , like i said call randy's ring and pinon they will be able to help you out. Google them
Do you have disc brakes in the front?
Mike
Old 06-05-2019, 06:41 AM   #5
Overdriven
Choosing whether to run 5 or 6 lug/stud usually comes down to wheel choice and what pattern they’re available in. Me personally I’ll be converting my 67 to 5 lug when I do brakes over the winter. As far as converting to rear disc, unless you are racing the truck there really isn’t a reason to other than looks.
I don’t know by the option code what rear axle housing you have, 12bolt or HO52. I know with the 12bolt Summit has 5 lug axles available for 67-70 and probably has 5 lug brake drums and the gaskets you’d need for easy shopping. No need for anything special and all stuff most can do themselves, unless you want to change the rear gear ratio which you didn’t mention.
Overdriven is offline   Reply With Quote
Old 06-05-2019, 06:47 AM   #6
Ganty101
I do have discs on the front, and I’m guessing there’s a lot more 5 stud wheel options than 6 stud? I dunno about calling Randy’s as I’m in the uk lol. I’ll try a few American car places here though they generally don’t know much about these trucks! I think I’ll stick to drums in the back then to keep cost down as the truck is standard basically.
Old 06-05-2019, 06:49 AM   #7
bigmac73
bigmac73's Avatar
true , discs brakes were available for 71 and up years, so some already did the conversion keep it like it is. I am sure it will drive fine
Mike
Old 06-05-2019, 07:35 AM   #8
Grumpy old man
Grumpy old man's Avatar
There are multiple 5 lug conversion rear axle kits on ebay with rear axle bearings and drums , Also Summit ,Jegs etc,etc ,Also 6 lug front disc rotors/ bearing kits if you decide to stay 6 lug .
Old 06-05-2019, 07:54 AM   #9
v30crewcab
v30crewcab's Avatar
if its disc in the front, you can get 6lug rotors from summit for the front and call it done, unless you want to run 5 lug for a certain rim choice.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 06-05-2019, 07:54 AM   #10
MikeB
MikeB's Avatar
Are the fronts 5-on-5" truck wheels? I ask because some cheapie aftermarket disc brake conversion kits use passenger car rotors with 5-on-4.75" lug pattern.
When I converted my 69 C10's rears to 5-on-5", I simply had a race car machine shop re-drill the stock axle flanges and install new studs. They also turned down the diameter of the wheel locators a little (around .050"?) to allow 73-up wheels to be used. That was done in the mid-1990s, and haven't had any issues.
FYI, 71-72 axles are longer than 69 axles, so they won't work in your housing.
Mike
1969 C10 LWB -- owned for 36 years. 350/TH350, 3.08 posi, 1st Gen Vintage Air, recent AAW wiring harness, 5-lug conversion, 1985 spindles and brakes.
1982 C10 SWB -- converted from 250-six to roller cam 350, Vortec heads -- sold
1981 C10 Silverado LWB, 305, TH350C -- sold, but wish I still had it!
1969 C10 (not the current one) that I bought in the early 1980s. Paid $1200; sold for $1500 a few years later. Just a hint at the appreciation that was coming.
Retired as a factory automation products salesman.
Worked part-time over the years for an engine builder and a classic car repair shop.
Member here for 24 years! This is the very first car/truck Internet forum I joined. I still used a dial-up modem back then!
MikeB is offline   Reply With Quote
