![]() Join Date: Jan 2018
Ford Windstar E-fan with LS Wiring
I have searched for hours on this and find similar threads even one title Ford Windstar E-fan wiring but it is showing a off/on type fan. Here is what I have:
LS with Standalone Harness: 2 wires (Lo and Hi) Ford Windstar E-fan: 3 wires (blue/blk/blk) on each fan; I assume this is Lo/High/Ground in some order I am trying to figure out how to wire relays for 3-prong fans, I see a ton of information on 2 prong dual fans. To add more complexity, I will be adding vintage air in a few months and will need to wire a trinary in as well. I found this and it is the simplest I have seen but for dual 2-prong fans.
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668 |
![]() Join Date: Aug 2004
Re: Ford Windstar E-fan with LS Wiring
They pull a TON of amps when they start! This was the only reason I desired against them.
The ones I have pull about 35amps at start up, through a relay like you. I got them from Champion Radiator Mine is also set up with a trinary switch so AC triggers also
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#3 | |
As for a/c trinary for the fans . Nothing will be different for the fans if you wire it in the pcm like gm did , which I recommend . Last edited by homemade87; 05-12-2019 at 08:20 AM. |
That helps a lot, thanks so much. Do I just use the blue wire for power and the black for ground and leave the other black for nothing then?
I found this on LS1Tech and I think it is the way I will want to go...
I am going with the 3 relay method such as below. From what I can deduct the 3 gray wires are the power wires to the fans so I should use heavy gauge wire (like 10 gauge). The 2 blues and 1 black are the grounds and I can just use like an 18 gauge black wire for these. Just want to make sure I have this correct in my head so I don't run a small wire for a power wire.
#7 | |
BMW & ASE Master Certified
all wires for 87, 87a and 30 is 12 or 10 ga. 85/86 terminals is 20 ga
1987 Silverado - L83 5.3 w/ 6L80e ,A/C,P/W,P/L,TILT, HID projectors, Wilwood C-10 Pro Spindles w/ 2018 silverado front brakes & C-5 Corvette Rear Disc Brakes 1999 BMW 528i - 5.7 LS1 w/ 4l60e, Ford 8.8 IRS w31 spline posi & FX-r projector retrofit New project: 2006 BMW x5 6cyl AWD to L83 6l80e 4wd to 2WD / RWD A poor man buy's it twice finally got my domain name back, 87chevy.com.... site rework in progress Last edited by 87chevy.com; 05-18-2019 at 10:46 PM. Reason: 85 is power, 86 ground edited |
