LS1 Alternator bracket help
Hi Guys
Iv got a bit of an issue, Id like to relocate my alternator to the top and to the side however none of the brackets I see would work with my power steering. ![]() ![]() ![]() As you can see from these sample pics, my PS reseviour is the see through plastic type however all the brackets that iv seen have the built in black ones Example: ![]() ![]() Is there a difference between these 2 styles or is it all the same? Any help or tips would be appreciated! Thanks |
![]() ![]() Join Date: May 2015
Re: LS1 Alternator bracket help
looks like to run alt up high youd have to change p.s.p. and brackets as well...just a guess though
That last pic is of a vette system, its totally different from the GTO. You would have to change everything, including the crank pulley and watt pump to use that. What kind of car is it in? Looks like the low mount would work.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
#4 | |
![]() ![]() Single piece PS ![]() My PS looks like this ![]() |
is the last truck pic yours? purple truck?...if the engine fits ,whats wrong with leaving alt and pump as is?
#6 | |
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=731589 The reason I want to move it up is because its uncomfortably close to the frame rail...moving it up would make things easier |
Could you just notch the frame rail?...how close is it?
