Old 05-21-2019, 08:39 PM   #1
T/C
T/C's Avatar
Cupped lower question
Okay i have some 9” rings to do my lower i had seen several places that the 8” pipe was to small for 2600s and i got 9” for free
Just wondering about placement i made my mark to stay centered with the factory spring mounting location.
Looking at cups others have done they didn’t center it all the way to avoid the shock mount area.
The 9” will require removing some of that material if i stay centered.
Thoughts suggestions?
T/C is offline   Reply With Quote
Old 05-22-2019, 04:21 PM   #2
tinydb84
tinydb84's Avatar
Re: Cupped lower question
You can move it away from the shock mount. You may need to drill holes in your upper mounting plate if you move it too far.
David
Instagram: myfabguy
Old 05-22-2019, 11:15 PM   #3
Backpayne
I installed 8" cups and it was about 1/2" from the shock bracket, so yours looks right on.
Backpayne is offline   Reply With Quote
