Anyone cut coil springs on 67-72 truck? How much cut and how much drop happened?
I am thinking about cutting front and rear coil springs on my 1968 chevy shortbed fleetside. Has anybody here done this? HOw much did you cut and how much did it drop? Did you notice a big difference in ride quality?
![]() Join Date: Jun 2002
Re: Anyone cut coil springs on 67-72 truck? How much cut and how much drop happened?
One coil from front equals 2-2.5" drop. Rear coils should not be cut (i used to say they couldn't be, but since then I have seen some really sketchy stuff) . As cheap as coils springs are I'd just buy some.
Roger '68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675 '69 ('70?) 2wd Blazer - https://67-72chevytrucks.com/vboard/...d.php?t=856475 '70 GMC Jimmy 2wd '73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203 Ideas - https://67-72chevytrucks.com/vboard/...d.php?t=851743 |
I wouldn't cut them either. I'd do it correctly from the start.
72 C10 lwb fleetside -stock 350/350 combo |
That would consist of what? I'm not being a smarta** - I'm trying to learn. Still trying to figure out how to drop my '71.
1971 C10 - Hugger Orange/White My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=780197 LS Swap Thread: https://67-72chevytrucks.com/vboard/...d.php?t=811460 |
Yep, one full coil equals about 2"...
1970 C/10 350/T5 SWB stepper... 1979 Corvette 350/Auto T-top... 2010 Acura RL... 2015 2500HD Z-71 Silverado... |
![]() Join Date: Jan 2018
Rear coils can be purchased from a lot of different companies for $100 in any drop amount you want (mostly). To do this effectively over 3" or so, you will need shock relocators and an adjustable panhard bar. 6" and up generally need a c-notch added.
My Daily Driver Build: http://67-72chevytrucks.com/vboard/s...d.php?t=755668 |
^^^This. Get new coils of whatever drop you want so you don't mess up the performance of the spring by cutting or heating them.
![]() Join Date: Jan 2016
One thing I learned about this the hard way. Old springs sag over time. I had 2.5" drop spindles but wanted another inch in the front. I bought 1 inch lowering springs, installed them only to find the front was now an inch higher not a inch lower. I ended up cutting a half coil to get the one inch I was looking for. No change to ride quality. So if you buy new springs make sure what you get will really give you the drop you want.
1967 C10 Step side 1970 AMX 390 1977 Datsun 280Z highly modified with '95 LT1 power |
Id be looking at craigslist for some springs first.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
I dropped mine 4.5 front and 6 in the rear. You can check out the parts, process and results here: http://67-72chevytrucks.com/vboard/s...d.php?t=612794
I know some people cut springs, but like people said, new drop coils are cheap. |
#11 | |
https://www.youtube.com/watch?v=VHPosx2oStU
this is what i used and it is darn near as precise as you can get helped me out a lot dialing mine in |
#13 | |
I dropped my 69 4 1/2" in the front and 7" in the rear. I used the conversion disc spindles from Early Classic Enterprises and a 2" drop spring. The rear of my truck is leaf and flipped with a DJM kit.
Sweet truck mike c! It just looks right!
Oh and don’t cut your coils guys! Do yourself a favor and buy lowered springs! Last edited by Ganty101; 06-05-2019 at 05:11 AM. |
