1/2 ton caliper pin bolt
Need help, I stripped out a caliper pin bolt on 83 1/2 ton. I need the thread size Were I can tap it out or Heli - coil it. Don’t want to replace spindle it’s a 2.5 lowering one. Thanks !!
![]() Last edited by Kuzican; 06-15-2019 at 12:56 PM. |
Re: 1/2 ton caliper pin bolt
I did the same thing on my C20. Napa had a "repair" pin that I used. Slightly oversized threads and a little harder steel to cut new threads. Worked good except they say it's a one time use only.
Any one know? 7/16-20 ? 11-1.5 ?
![]() ![]() Join Date: May 2015
I looked when you 1st posted but couldn't find a definite answer...sometime in the early 80s they went from standard to metric...take one of your bolts to your local parts store,,,or fastenal if you have one close by ...most have a thread pitch gauge and they can tell you if its standard or metric....
![]() Join Date: Mar 2003
7/16.
Brazed up the sides of the hole in mine and re-tapped it for the stock pin, figured if that failed the oversize pin will be plan B.
