Old 11-20-2003, 01:15 PM   #1
cochino12
It followed me home?
cochino12's Avatar
headers= loss of power?
Is it true switching from full length headers to shorty headers would result in a loss of power. I was told I dropped about 10-15 hp when I swithed to my shortys.
Adam
That's why they call it a shortcut Kyle, if it was easy it would just be the way.
86 c-10 SWB
85 CCSB
90 GMC K30 Crew SRW
1985 C30 Dually
cochino12 is offline   Reply With Quote
Old 11-20-2003, 02:05 PM   #2
bigblock73
yeller
bigblock73's Avatar
Full length headers will flow the best, so if you think about it, anything less won't flow/perform as well and there will be a slight decrease in power. I don't think a 10-15 HP loss is realistic...maybe 2-3 or so. A 10-15 loss wold be like going to full length headers to exhaust manifolds.
-Jeff
bigblock73 is offline   Reply With Quote
Old 11-20-2003, 02:20 PM   #3
81lwb350
big block lover
i was told that full length headers give more torque than shorty's.
81 custom deluxe lwb
454 bored .030 over w/ small RV cam.
2.5 exaust- thrush turbo muffs.
th350 getting beefed up soon!
81lwb350 is offline   Reply With Quote
Old 11-20-2003, 02:23 PM   #4
bigblock73
yeller
bigblock73's Avatar
Avatar time 81lwb350!!!
-Jeff
Old 11-20-2003, 03:40 PM   #5
loweredd
www.loweredd.com
loweredd's Avatar
I agree with the full length to manifolds. My truck cant even get out of its way now. I had to ditch my full lengths and put on manifolds when I bagged it. I need to find some shorties now for sure!
loweredd is offline   Reply With Quote
Old 11-20-2003, 07:41 PM   #6
81lwb350
big block lover
whoo hooo.....finally 100 posts......whoo hoo......gotta get me an avatar....whoo hoooooooooooooo...
sorry to hijack this thread....
not something i usually do!.... lol
Old 11-20-2003, 09:44 PM   #7
cgrossl
The header primary length and the collector length have a bigger affect on what RPM that peak power is achieved rather than how much. Shorter primary tubes will result in horsepower and torque peaks that come at a higher RPM. Longer primary tubes will result in horsepower and torqe peaks that come at a lower RPM. There probably won't be much of a difference in the peak number, just at what RPM it occurs at. In a truck, you would probably be much better off with full length headers.
If you really want to know alot more about this, go to http://www.headerdesign.com/ and start reading. There is also a free calculator that will calculate the optimum primary size and length, and the optimum collector size and length. You will probably be surprised to find out that most headers out there aren't designed very efficiently.
cgrossl is offline   Reply With Quote
Old 11-30-2003, 10:35 PM   #8
stepside454
stepside454's Avatar
I switched from full length to Sanderson Shortys on my 454 C10. if I lost anything on bottom, it hasnt hurt me.. but it does feel stronger on top.
75 GMC C-15 short/step factory 454, lowered
stepside454 is offline   Reply With Quote
