Old 05-31-2019, 08:39 PM   #1
jbgroby
jbgroby's Avatar
Auto Trans swap from 4sp Hydramatic to 700R4
Ok, although I'm taking the truck to a trans shop next Friday, we suspect the trans will need to be rebuilt. So far, the two prices I've gotten on rebuild are both about $3400. Unless I find find a club member with one to sell, the $3400 amount is outside of the amount I wish to spend. I was told that because I have the automatic now with the adaptor plate, other automatics will bolt up.
I need to see which trans will do so. I also suspect that I'll need to change the steering column as well.
Any member with knowedge on this type of swap, I'd like you to chime in and provide insite. Right now I don't know what trans to begin looking at. I was told a 700r4 will do then it was suggested that I should also consider one with overdrive for highway cruising.
Jake Groby
jbgroby is offline   Reply With Quote
