![]() Join Date: Feb 2003
Rear axle springs
Wanting to find out what the standard amount of leaves would be in the rear axle springs on my 83 1 ton 4x4. There are nine leaves with two helpers right now. The truck was originally used to pull a goose neck.
Re: Rear axle springs
1tons tend to have 9 leaf + overload in the rear for the main pack . then 1 or more extra on top if it calls for helper leafs .
77-k30lb BIG truck build . 87-k30lb budget beater build . 85-k30lb the plow machine build . 85-c10sb summer fun toy . ----------------------------- HOLLEY SNIPER efi = worst case of p.i.t.a i ever had . EDELBROCK pro flo 4 = best deal going so far . love my setup works great. |
1 tons had between 8/1 and 12/1 springs, not including any helper springs. typically 1-3 helper springs.
8/1 is 8 leafs with the 1 fat thick overload at the bottom, so on and so forth. |
My 89 C3500 cab and chassis has 8 plus an overload at the top and a fat one at the bottom.
"Whoever said money can't buy happiness has obviously never seen a speed shop! |
Appreciate the info. Thanks.
