![]() Join Date: Feb 2001
What to do with bad radiators (original brass)
I just went through a stack of 4 flue radiators that I pulled off trucks I've parted over the years. They are not in the greatest shape and some have visible holes in the flues. My last trip scrap yard, I got $42 for a couple of junky 3 core radiators but I hate to scrap these bigger ones! Are just the tanks worth anything? Can the radiators be re-cored - expensive? Thanks for any help.
72 Cheyenne Super swb. Factory 402/400,tach,posi,AM/FM, A/C. Adding cruise, 8-track 72 Cheyenne Super swb. 350/350 A/C, bucket seats 72 Cheyenne swb. Factory 402/400, tilt, posi, A/C 72 Cheyenne Super K-10. 350/4 spd., posi. 72 Suburban 350/350 tilt, tach, AM/FM, A/C, luggage rack 72 GMC Sierra lwb. 350/350, A/C. medium green/olive interior |
Re: What to do with bad radiators (original brass)
A new brass radiator is $600.
Will the local radiator shop buy them for cores? |
![]() Join Date: Sep 2005
my locl shop quoted me like 600 for recore my original bass rad that was leaking since i was going ls swap i just bought an alumina rad
Carpe manana
![]() ![]() Join Date: Dec 2010
I had an OEM Harrison 4 row re cored using the original tanks for my Blazer build - cost was about $450 I recall. Not cheap but it’s also not an ill-fitting reproduction piece.
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
Save the tanks, I had one re cored for $325
68 GMC C3500 Longhorn DRW 67 Chevy C10 LWB 90 Mustang Gt 90 Mustang Notchback |
Get quotes on a re-core. See if anyone locally wants to buy one for a re-core. Maybe a few dollars over scrap price??
1970 C10 8' Fleetside, L6 250, 3 on the Tree. The most basic of pickup trucks! |
![]() Join Date: Apr 2016
I listed my used original radiator here on the forum in the parts section, and somebody bought it immediately and he paid more for shipping than for the radiator, if I remember correctly. I believe the radiators have value to somebody even if you don't plan to re-core it for your own use. That is true of most components off the trucks, including stuff that you think is junk. Some of the stuff is not reproduced, such as if you're getting rid of the original air cleaner and spacer that goes under it, and replacing the flame arrestor and hose that goes between the spacer and flame arrestor on the valve cover, somebody needs that. Or the boring stock valve covers, if you're getting some chrome ones, somebody will be happy to have the stock ones. Even old wiring harnesses are useful. So, I recommend list everything you can and offer it up for others to buy or have. I even had somebody happy to take my windshield that was delaminating around the edges.
Yeah I bought an aluminum 3 row for my truck when I rebuilt the engine and trans. Now i just have the old 4 core brass and copper sitting in the box the new radiator came in.
"Work hard, use your vacation days." 1970 C15 GMC Long Bed 1986 C20 Scottsdale 1983 K2500 Sierra Classic Suburban 6.2 Instagram: C10sofOC |
I had mine recored and never looked back,, OEM tanks are thicker than the repops. Here is the kicker I have a 2 row 1 inch tubes champion and the oem 4 core for my 70 truck, using the same electric fans , the fans pulled better air flow on the brass. The brass set up would hold both boxes that the fans came in stuck to the rad and had to pull them away from the rad. When the champion rad was in place with the same fans it would not hold the boxes to the rad, as if the fans were not even on. They would hold shop towels up to it but not much needed to remove them from the rad. So I stuck with the brass set up. keeps the truck right at the T-stat . The champion would rise on the temps at idle it would rise ten degrees easy, going down the road it would slowly drop back to the T-stat temp. Ya the motor set up for racing but like to cruise to local car shows in our town, so no it doesn't get alot of miles.
New Member
![]() Join Date: Jan 2019
Recoring can cost over $500 and even new brass/copper ones are $450+.
That's why aluminum has gotten so popular now! And are great for all but the original concours fanatics. |
![]() Join Date: Dec 2006
Take them to a good shop and ask about them. In May my original brass radiator blew up at the seams after a very bad overheating. I found a place that soldered it all up and put a brace on it for $45. Works like new.
'69 GMC C2500 Custom Camper, 8 1/2' bed, New GM 350, NP 435 Close Ratio 4spd. Trans., 3.73 Dana-60 open.Camper and Trailer wiring, PS, PB, AC, tach , three gas tanks, stereo speakers, 2nd owner, Work-Truck supreme. |
Who Changed This?
![]() Join Date: Jan 2013
I bought a ColdCase radiator awhile back and it works just fine. Fit in the factory location like original. I like it when engineering works.
New Member
Carpe manana
Where are ColdCase radiators produced?
#15 |
New Member
#16 |
Carpe manana
Thank you for the follow-up
#17 | |
One of the First
![]() Join Date: Jan 2000
But thanks for being a vendor on this site and providing us with alternate means to drive our vintage stuff!
DAVID PASSMORE ST AUGUSTINE ,FL ZIP 32084 '71 SWB K/10 CUSTOM DELUXE (Chili) '72 BLAZER K/5 Muscle Truck (Mule) '72 LWB K/20 CHEYENNE (Blackie) |
#18 | |
New Member
If you'd rather search and pay for the NOS or Original stuff, by all means, go for it. Exactly what you said, we are just offering a reasonable option for those looking for replacements. |
