8 lug rear end
Are the 3/4 and 1 ton(single tire) 8 lug rear axles the same ???
Do they vary from 2 wheel drive to 4 wheel drive ??? |
Re: 8 lug rear end
On the 3/4 ton, some were semi float and some were full float. The big block trucks and the crew cabs got full floats
All of the 1 ton trucks had the full float. |
Re: 8 lug rear end
3/4 tons and one tons have different brake setup the one ton has wider shoes so the backing plates have a dish shape and the 3/4 ton are more flat
Re: 8 lug rear end
Diesel 3/4t also got the full-floater. I know the 5spd ones did.
At the body shop.
Re: 8 lug rear end
The 454 8600 gvw crew cab did too
" That didnt make it any newer " " Dont antique the equipment " |
Re: 8 lug rear end
my 84 diesel 3/4 had a semi-float. it was a 4 speed. no such thing as a 5 speed in a square unless it was bigger than a ton.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205 86 k30, 89 diesel burb, 76 gmc pathfinder 71 longbed 5.3 4l80 http://67-72chevytrucks.com/vboard/s...d.php?t=522535 |
Re: 8 lug rear end
Are the gas 3/4 ton 2wd and 4wd 8 lug (semi) rear ends the same ???
Re: 8 lug rear end
My '99 3/4 ton SWB crew-cab has a 5.7/4l80e combo & has the 9.5"/14bolt SF rear. Maybe the 10.5/14bolt FF was a standard BBC thing & optional for SBC's?
Re: 8 lug rear end
Don't go confusing things up. This is the 88-98 forum, so no need to talk about apples when the topic is oranges. And the 5spds in MD trucks, which is yet another topic, were not O/D or anything close to what came in LD trucks of any year
#10 | |
Moderator
![]() Join Date: Oct 2008
Re: 8 lug rear end
High GVWR 3/4 and SRW 1 ton can have the same size brakes. JB5 = Vacuum booster JD5 = Hydroboost JB6 = Vacuum booster JD6 = Hydroboost JB7 = Vacuum booster JD7 = Hydroboost JB8 (single wheel) = Hydroboost JB8 (dual wheel) = Hydroboost JF9 = Hydroboost xx6 uses 11.15 x 2.75 Duo-Servo drums xx7 and xx8 use 12.5 x 1.26 rotors... except JB8 with dual rear wheels that has 12.5 x 1.5 rotors. xx7 has 13 x 2.5 rear drums xx8 has 13 x 3.5 rear drums JF9 has 13.86 x 1.435 front rotors and 13.58 x 1.435 rear rotors
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
