Bad frame cracks, can it be fixed?
Re: Bad frame cracks, can it be fixed?
A knowledgeable welder can fix that very easily with the correct repair procedure. Shouldnt be any problem at all.
1972 k10 Custom 10 Deluxe, short bed 4x4, 454, 4 speed (Sold) 1985 K30 Dump Truck 1986 Jeep CJ-7 1955 2 door 210 post |
Yeah, you could stop drill the cracks and weld them up. The frame area where you seem to have cracks doesn't look rusted out at all, why did the cracks appear there? Accident and/or overloaded?? I'm not sure if fish plates would be necessary. Looks like you have access to weld from both sides, and frame isn't that thick. But someone more knowledgeable would know better.
![]() Join Date: Aug 2004
That would weld up ok, probably be a good idea to add a backing plate to the damaged area.
I’m wondering if you are out of square after whatever caused that damage. Maybe a front end sideways wipe from R to L type of hit? It doesn’t take much to bend a frame. It’s worth looking at the opposite side to see if there’s any deformation. Usually looks like the top or bottom of the c-channel is pushed up/down in a spot or is wavy from being hammered back to shape. If you do see any of that, find a shop with a frame bench and willingness to work on something old.
ClusterTruck: 68 C10 Bought in 89, wrecked in 03. Slow low $ rebuild started '17. 6.0 & TKO http://67-72chevytrucks.com/vboard/s...d.php?t=788602 93 K1500 Short Step, 350, NV4500, EBL flash ECU. Vortec heads & roller cam someday... 05 Jeep Wrangler Unlimited. 3” lift & 6-speed 02 E320 the insurance total “free car” 13 Tahoe LTZ Last edited by clay68c10; 07-23-2019 at 11:07 PM. |
![]() Join Date: Mar 2003
Totally repairable. Weld up, smooth down, check for straight
All about them K’s
![]() Join Date: Jun 2014
Yep I agree. I repaired my frame where the steering box mounts up. That one looks a lot easier than what I had to deal with.
Tyler '57 3100 http://67-72chevytrucks.com/vboard/s...d.php?t=813888 '72 K20 Cheyenne: 5” lift, 35’s, front dana 60 blah blah blah… http://67-72chevytrucks.com/vboard/s...d.php?t=662879 ‘69 K10 SWB: 4” lift 33”s… in a million pieces http://67-72chevytrucks.com/vboard/s...d.php?t=805206 '98 Silverado LT K2500HD ECLB Vortec 454/4l80E: 6" lift 35x12.5x20’s |
