Old 07-30-2019, 05:36 PM   #1
bigmac73
bigmac73's Avatar
fire wall pads
So i am stripping my cab for the paint shop, the old firewall pads just fell apart.
So do i need to put new ones back in ??
who is running with and with out them?
Pros and cons??
Mike
72 C-10 Cheyenne off frame resto and Upgraded to 4 wheel disk, Tilt, Dakota Digital Dash / Rear slider.
421 SBC / TH350 3000RPM Stall
Progression Ignition /Holley 750 DP/3:73 gear Eaton Limited Slip unit / 2 1/2 exhaust glasspacks
bigmac73 is offline   Reply With Quote
Old 07-30-2019, 05:40 PM   #2
68Blu
Re: fire wall pads
I’m also wondering about this. But to go a step further, could sound deadener (dynomat) replace the firewall pad? Thanks
68Blu is offline   Reply With Quote
Old 07-30-2019, 05:52 PM   #3
MDPotter
MDPotter's Avatar
Re: fire wall pads
I don't know how much difference they make. From what I can tell, they're mostly for thermal insulation and maybe a little bit of sound deadening. We didn't install them on my dad's 64 - we just put on generic dynamat and it's not too loud. I've already welded shut the holes for the attachment of that pad on my cab, it's just cleaner that way and I hate messing with that material when I'm under the dash working on something.
1964 Chevy C10 - Gen IV 5.3 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=768632
1968 GMC C15 - Gen III 6.0 Restomod http://67-72chevytrucks.com/vboard/s...d.php?t=772047
1969 Chevy C10 - Restoration http://67-72chevytrucks.com/vboard/s...d.php?t=809184
1978 Chevy Scottsdale K20
1993 Chevy C1500 - 5.3/T56 swapped
2008 Silverado Duramax
MDPotter is offline   Reply With Quote
Old 07-30-2019, 07:27 PM   #4
notsolo
notsolo's Avatar
Re: fire wall pads
I used rattle trap, instead of dynomat. About the same, also added close celled foam, from Low Buck Rod....it's nice, and not bubble wrap....Mine went almost all the way up under the dash, then piece of vinyl from long ago, instead of the cardboard and jute....I think it was called tarkit....Then carpet.
notsolo is offline   Reply With Quote
Old 07-30-2019, 09:01 PM   #5
landarts
landarts
Re: fire wall pads
I got mine from LMC truck, there are three separate sections about $30 each section. Here is the link to page 109 top right corner. http://www.lmctruck.com/icatalog/CB/full.aspx?page=109
Super Cheyenne aka the "Devil Cowboy"
71 K20 Idaho Edition
69 K10 from the Field
68 Second Chance
Fix and Sale 72 GMC 3/4 ton 4x4 K2500
The "Fixrupr" build thread
72 Cheyenne 1/2 ton " FIXRUPR " - daily driver
67 C20 all original paint
71 K20 Custom 4x4 (Idaho Edition)
72 K20 GMC Super Custom 4x4
72 K20 Custom Deluxe 4x4
69 K10 Custom package 4x4 (69 K10 from the field)
72 K10 Custom
71 K10 Custom
72 K20 Crew Cab Project
71 GMC Jimmy CST
72 Blazer
70 Blazer
landarts is offline   Reply With Quote
