Old 08-05-2019, 04:25 PM   #1
Mains52
Other GM Steering Columns ? Anyone use one in their AD?
So if I was to go to an old classic salvage yard and grab a steering column out of an classic gm car with column shift I'd assume it could work for my 53 right ?
Mains52 is offline   Reply With Quote
Old 08-05-2019, 09:37 PM   #2
72Mountaineer
72Mountaineer's Avatar
Re: Other GM Steering Columns ? Anyone use one in their AD?
I used one from an early 80s Chevy van, good length and tilt.
72Mountaineer is offline   Reply With Quote
Old 08-05-2019, 10:54 PM   #3
Mains52
Thanks I'll keep an eye out in my salvage yard trip.
Old 08-07-2019, 08:21 PM   #4
vintovka
vintovka's Avatar
I used one out of a 87 GMC Van. Works great BUT won't take any side load (like hauling my 230 pound butt into my lifted cab). I had to put grab rails inside and out and train myself to use them instead of grabbing the wheel. See link with pics. GM columns will break and wobble around like a 1" broomhandle in a 2" pipe when used to long as a grab rail. Check any one you consider carefully as many are old and heavily used. I had it kinda fixed by swapping less worn upper parts from a donor but now the lower bearing needs replaced. That said, the ones with the OD setting work great along with the stalk controls like turn signals, hi low, emergency flasher ect. Length is right and tilt is a must as wheel grows closer to your gut with the years. If I had it to do all over i would have installed a whole rebuild kit BEFORE. Be warned the repair parts arn't cheap.
vintovka is offline   Reply With Quote
Old 08-07-2019, 08:31 PM   #5
LEEVON
Moderator
LEEVON's Avatar
I used a non-tilt automatic column from my '71 in my '50 because I had it laying around. I shortened it exactly 2" by sectioning the tube and shaft then replaced bearings, painted, etc. Had maybe $50 into it, it looks new and works great. I did have to use a 60's c10 wheel due to the hub/mounting area diameter.
'86 GMC C30 Crew ~ '86 C20 Crew ~ '79 K15 Sierra Grande ~ '76 Blazer 2wd ~ '74K10 ~ '71 Cheyenne swb ~'50 3100 bagged ~ '80 Wife ~ Late model kids
LEEVON is offline   Reply With Quote
