A few parts I need to get rid of
1. TH305c lockup tranny, good for core, slipped in first gear, shifted fine and reverse worked when pulled. $50 bucks
2. Chrome bull bar that will fit 73-80 model trucks, has some surafce rust, should clean up. $40 bucks 3. 1/2 ton sway bar with plates, bushings, and frame brackets. $35 Pending 4. 406 small block package! 400 block bored .030" over, hot tanked, and painted, has new cam bearings and freeze plugs installed. I'm including the crank, rods, and old pistons with it, also factory windage tray oil pan, painted same as block, chrome timing cover, old pushrods, and cylinder heads (not sure if their good for anything but should be good for a rebuildable core) Also included is a perfectly good edlebrock torker II intake and Holley manual choke, vacuum secondary 600cfm carb. All of this for $400 dollars. Have a few waterpumps if you want to use them for cores. Pending I can get pictures of any of these items listed, just email me at chad@martiansales.com , pm me or leave a message in the thread. Last edited by Destructo; 12-05-2003 at 05:36 PM. |
