Engine Fan part
Hello all,
I have a 1969 blazer that was converted to electric fan by the PO and wanted to put it back to the original mechanical fan setup. Can someone tell me where to find the correct setup for this. I’ve looked a little and Ive found alot on electric fans but not much on mechanical fans. Part numbers and manufacturers or just a website is all I need. Trying to get it running for when the temps drop below 100 here in Mississippi. The current electric fan is shot and will not run in case anyone is wondering why I want to switch. Thanks in advance. |
![]() Join Date: Jan 2001
Re: Engine Fan part
Honestly, I think your best bet is going to be a wrecking yard or a board member.
I have sworn upon the altar of God, eternal hostility against every form of tyranny over the mind of man. - Thomas Jefferson |
![]() Join Date: May 2011
Re: Engine Fan part
I should have a fan and spacer but don't know about the pump pulley. Do you still have the original fan shroud.
