Active Member
![]() Join Date: Jan 2016
Tire size questions
Hey Everybody!
I might have already covered this somewhere on the board, but I came across some new Goodyear tires for $75/pair. They're 215/60/R16. Are these tires safe for 16 x 6.5 steelie rims on a '72 C20 RWD? I'd like to put them on the front and eventually the same size on the back. What's the widest tire I can put on the back on a 16 x 6.5 rim? If anyone would drop any advice, criticism, and opinions, that would be helpful. Thanks!!
Re: Tire size questions
Widest suggested you can go on a 6.5" rim is around 245. Factory should be 235 on a 6", which is wider than suggested for that size rim. Typically 225 is the widest you should go on a 6" rim. I think it is basically, you want the tire width to be less than 1.5x the width of the rim.
215 - 8.77" 225 - 8.85" 235 - 9.25" 245 - 9.64" 255 - 10.04" 6" * 1.5 = 9" 6.5" * 1.5 = 9.75" Stock tire on a 72 C20 should be 235/85R16, which are 31.7". The 215/60R16 tires are 26.2". Your speedo will be way off unless it has been changed from stock. You will run at a higher RPM on the highway.
1970 C20 Custom Camper - 350, TH350 1997 GMC Suburban 1994 Acura Integra GSR 1987 Dodge Daytona Shelby Z |
#3 | |
Active Member
I used a "Tire Size Calculator". https://tiresize.com/calculator/ Worked great to determine the tire and wheel sizes on our C20.
If you look up the tire size you want to run on TireRack or Discount Tire it gives you a wheel width range that tire will work on.
Speedo is calculated off the rear, so that could work. The front tires will be 5.5" smaller though.
Active Member
So, update on the tire ordeal. I gotta tire guy. A husband of my wife's coworker has suggested a 255/70/R16. Claims smooth ride and a little lower for a cooler look. The speedo might be off by 5mph at 60 mph or so, but meh. No biggie. Whatcha all think? What brand of tires are you running that look cool? I imagine it'll be a long time before I wear these tires down as I only drive it spring through fall on weekends, really. Finally got the old steelies powder coated. I'll have to post the pics when I get a chance.
