1978 250 Inline 6 cylinder oil pump issue Advise
So, I rebuilt my dads 1978 inline 250. Question is....why would the oil pump take so much force to spin? When I took it out of the box before assembly, it spun fine. Now its installed and when I initially primed the engine, the drill struggled with spinning it. And when I stopped spinning it, it spun backwards for a moment or 2. Now since break in is over, I figured it would loosen up, but it hasn't. It will actually almost stall the engine when 50 lbs is reached. Any thoughts or advise would be appreciated. Thanks in advance.
Moderator
![]() Join Date: Oct 2008
Re: 1978 250 Inline 6 cylinder oil pump issue Advise
Something is binding when the pump is bolted to the block.
Poorly machined and or cast part? Third world QC procedures. You machine a part like this using a baseline reference plane. That plane becomes your zero surface and all other operations are setup in relation to that plane. If that surface is not properly machined the pump gears and shaft will be machined such that the plane of the gears and stub shaft are at the wrong angle when bolted to the block. This could be from overlooking core shift in the castings or just plain sloppy machine work. IMHO it's sloppy workmanship to overlook core shift that essentially scraps the part before you take the first cut. Skeevy third world manufacturers often machine parts from castings that don't pass muster such that they will pass a cursory visual check. Then they ship em rather than reject poorly cast blanks. Hence my comments in other posts about riding these types of suppliers like a $2 horse. The protruding oil pump shaft is contacting something in the block that it ain't supposed to because it was not properly aligned with the mounting holes? The end play between the steel gears and the cover plate is too tight? The hole for the steel shaft is not machined to the proper dimension so it's binding in the pump?
1959 M35A2 LDT465-1D SOLD 1967 Dodge W200 B383, NP420/NP201 SOLD 1969 Dodge Polara 500 B383, A833 SOLD 1972 Ford F250 FE390, NP435/NP205 SOLD 1976 Chevy K20, 6.5L, NV4500/NP208 SOLD 1986 M1008 CUCV SOLD 2000 GMC C2500, TD6.5L, NV4500 2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263 2009 Impala SS LS4 V8 RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...
And please let us know if and how your repairs were successful. |
Thats good info. Thank you. Im not sure whats happening exactly. Would you recommend just replacing the pump or is there a procedure to test those various examples you listed? Its not an easy process to drop the an on this engine due to the timing cover bolting/sealing against the oil pan. Any suggestions would help. Thanks again.
![]() ![]() Join Date: Jul 2002
I think you should replace the pump. As mentioned something is not right, and it needs to be looked at/pulled apart.
