Old 10-16-2019, 02:40 PM   #1
eric8
Plug Wire Lengths
This might be a dumb question, but I ordered a new set of exact fit Denso plug wires for my 77 (350 with HEI distributor). As you can see, the lengths are all over the place. One wire is extra long, 3 are long, 1 kind of medium sized, and 3 are short. Is there a specific cylinder these are assigned to, or is just a "wing it" or trial and error kind of deal?
eric8 is offline   Reply With Quote
Old 10-16-2019, 03:10 PM   #2
sweetk30
sweetk30's Avatar
Re: Plug Wire Lengths
i tend to do cut to fit and crimp them my self anymore .
it seems every few years DIRECT fit wire sets grow a few inches . . . there almost always to dam long .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 10-16-2019, 06:02 PM   #3
Dead Parrot
I usually start with the shortest wire and find the best fit. Repeat until you have all 8 done. Last couple usually wind up being a little long. Better a couple inches too long then a couple inches too short. Yes, 'wing it and trial and error'.
Dead Parrot is offline   Reply With Quote
Old 10-16-2019, 10:52 PM   #4
eric8
Well for what it's worth, I did some digging and found a post on another site that said for a sbc, the plug wire lengths generally go in the following order (from longest wire to shortest wire): cylinder #'s 3,2,1,4,5,7,6,8
I used this method and the wires look good.
Old 10-17-2019, 08:20 AM   #5
Katrina/10
Katrina/10's Avatar
I put some wires on my truck just a couple days ago, and ran into the same thing. Always a box full of unmarked wires, no indication where they go. I didn't think to look on the internet to see if there was a recommended sequence for length, that was a good idea!
I tried to guess which ones would go where by laying them out on the floor by cylinder location, it didn't work perfectly, but helped. I did find that the longest one worked best for number 3.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 10-17-2019, 08:42 AM   #6
rpmerf
rpmerf's Avatar
Interesting. Not what I would had guessed. When you look at a picture of it, it makes a bit more sense.
1970 C20 Custom Camper - 350, TH350
1997 GMC Suburban
1994 Acura Integra GSR
1987 Dodge Daytona Shelby Z
rpmerf is offline   Reply With Quote
Old 10-17-2019, 09:32 AM   #7
SunSoaked
SunSoaked's Avatar
This is why God invented the LS.
SunSoaked is offline   Reply With Quote
Old 10-17-2019, 11:39 AM   #8
1976gmc20
Except the distributor is nowhere near that large compared to the rest of the engine.
I always start with the longest one(s) on 1 or 2, then work down and hope.
And yeah most wire sets are hopelessly too long. I think I have some plug wires zip tied to the brake vacuum hose (anything non metallic), and maybe to a heater hose on the other side.
I had a rough running problem and replaced cap, rotor, wires, and plugs as a matter of course. Just kept getting worse and turned out it was a blown head gasket between 3 and 5. So I had a shop do that and a few weeks later it started running rough again! Then I discovered one of the plug wires dang near burned through on the exhaust manifold on that side. Obviously the shop didn't taking much care putting the plug wires back on
Current/past Chevy/GMC trucks:
1958 Chevy C-60; 1965 GMC C-50; 1965 Chevy C-10; 1971 Chevy K-10; 1973 Chevy K-20; 1976 GMC C-20; 1977 Chevy C-10 Suburban; 1980 Chevy K-10; 1989 Chevy K1500; 1991 GMC V1500 Suburban; 2016 Chevy K2500 HD
Other vehicles: 1988 Jeep XJ; 2011 Toyota 4Runner
1976gmc20 is offline   Reply With Quote
