11-27-2019, 02:55 PM | #1 |
Cummins Swap 1968 Suburban - wish list
I've followed posts on the site so i thought I would reach out for advice.
I'm gathering parts for a Suburban with Cummins build Heres what I have so far 1972 Suburban K10 rolling frame 1968 Suburban rust free body 1992 D250 Cummins Pickup with auto Rob Bonney Frame box kit & motor mounts With Black Friday here and vendors offering deals what would you buy? I'm older and don't want too much lift. This will be a daily driver - I live in Colorado. I believe the Front & Rear differentials (Dana 60 & 70) from my donor truck will work. Strong running 5.9 but it has the VE Rotary pump so looking for the required parts to upgrade to P Pump. The auto trans is slipping as it was a snow plow truck. thanks in advance. |
12-01-2019, 10:28 PM | #2 |
Re: Cummins Swap 1968 Suburban - wish list
I am dreaming of my own Cummins swap someday, but a VE pump is a good set up unless your shooting for big time power.
This is off memory here, and stuff i halve read. How true I do not know. The VE pump is good to roughly 500 hp with the right parts. Supposedly a bit easier to start the a P-pump, and slightly better mpg. Also quite a bit cheaper since no one wants them if you need spares compared to a P-pump. |
12-05-2019, 08:13 PM | #3 |
I run a VE in mine, it will get you to 400’s not so sure about 500...better off finding a p pump engine vs buying the swap items. it’s a great running truck and a blast to drive, do it!
68 GMC C3500 Longhorn DRW 67 Chevy C10 LWB 90 Mustang Gt 90 Mustang Notchback |
12-05-2019, 10:30 PM | #4 |
Good luck on your quest.
If you do a build thread make sure you post good info & details. 2years and I’m still collecting parts and struggling on info for my 67 4x4 cc Cummins build.
70 c10 2wd crashed Suburban 67 c10 2wd sb truck 67 c10 4wd lb truck |
