Old 12-13-2019, 08:41 PM   #1
Pirate83
Will it fit?
Found a rear end from a 2000 Silverado 4x4. Will it fin in a 63 c10? He says in the post it’s a GT4 G80 rear 3:73 ratio.
Pirate83 is offline   Reply With Quote
Old 12-13-2019, 10:15 PM   #2
Captainfab
60-66 Nut
Re: Will it fit?
The '00 10 bolt will be aprox 3" wider than your original '63 12 bolt. And then there will be cutting and welding involved. You will need to remove all of the factory brackets from the '00 10 bolt and weld trailing arm mounts and a panhard bar mount onto the '00 10 bolt at the correct distance and at the correct pinion angle. What is wrong with your original '63 12 bolt?
