Old 12-11-2019, 04:56 PM   #1
3QTRTONS
3QTRTONS's Avatar
GM column swap
OK, give me sh!t if I didn't search far enough but,,,
I need to replace the steering column in my 1980 3/4 ton 4wd manual trans truck.
Currently has a non tilt manual column, without cruise.
I have a 1980 C10 diesel tilt automatic column, without cruise.
I also have a pre-83 tilt automatic column, with cruise.
Also have harnesses, if need be.
Will the automatic column swap in? Any mods needed?
Any/all help appreciated. This is my Daily Driver.
1969 ES5500 B E A S T 1976 K20 Suburban
1983 C10 'farm truck' 1984 K10 Suburban
1988 V30 Fire Truck
1941 Dodge WC18 Ambulance
2000 GMC Bus (parts warehouse)
3QTRTONS is offline   Reply With Quote
Old 12-12-2019, 11:42 AM   #2
hatzie
Moderator
hatzie's Avatar
Re: GM column swap
You can use the AT column. The AT lever collar isn't aesthetically pleasing on a MT truck but it will work.
1978-1991 harmonica plugs are the same pinout. 73-77 are different.
1973-1991 Wipers, dimmer, and cruise are separate from the harmonica plug. 73-83 are on the dash and floor. 84-91 have wiper and dimmer switches on the column but you aren't required to use them.
The above is only the wiring. You still have to deal with the steering shafts. GM used a splined and a Double D end on the column. I'm not sure what years were what configuration.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 12-12-2019, 07:43 PM   #3
bhc41051
bhc41051's Avatar
Re: GM column swap
So the manual column is beyond repair?
bhc41051 is offline   Reply With Quote
