Old 06-29-2007, 01:50 AM   #1
jimmydean
jimmydean's Avatar
Dana 44 inner hub seal? What the heck?
So I was rebuilding the driver side hub after replacing the drive axle on my Dana 44. But when I went to NAPA to get the inner seal, they can't find it by number and nothing matches up!
It's the large seal pressed into the hub that sits against the rubber seal on the drive axle. Does anyone know the seal I'm talking about?
I got a kit from NAPA that included a new metal ring and seal that presses on to the outer drive axle, and it also included the roller bearing that is pressed into the hub itself. But I need to replace the large seal that goes outside the bearing on the back side of the hub.
Anyone have a part number? The number on the seal doesn't come up on NAPA's system. Autozone gave me a deer in the headlights look when I showed them the old one, so I just walked out.
A part number would be sweet. Thanks, guys.
New Project: 1966 LWB C20
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
http://67-72chevytrucks.com/vboard/s....php?p=4295210
jimmydean is offline   Reply With Quote
Old 06-29-2007, 02:11 AM   #2
wibilly
wibilly's Avatar
Re: Dana 44 inner hub seal? What the heck?
sorry no part # but i got mine at o'rylies, it may of still been bumper to bumper then. the quality of in stock parts has realy gone down hill since they changed hands. i found every thing but the tin deflecters for the outside of the inner axels them i had to make myself
common sense isn't so common anymore
wibilly is offline   Reply With Quote
Old 06-29-2007, 02:17 AM   #3
Random Guy
Random Guy's Avatar
I got the seal for my 68 with no problem from Autozone. It could have something to do with the fact that the manger was also 68 c10 owner, but he did say it was an in stock part.
CARPE CERVASIUM!
1968 C10 Fleetside LWB
Remember Cthulu is watching you!
Random Guy is offline   Reply With Quote
Old 06-29-2007, 08:23 AM   #4
woodridge
woodridge's Avatar
Is any of this what you need? Part # PBK1 at NAPA.
SEMA Network- Protect our Hobby!
71 C30 in pieces, starting to come together.
Click here for A Place For Tennessee Truck Enthusiest To Meet
woodridge is offline   Reply With Quote
Old 06-29-2007, 11:15 AM   #5
jimmydean
jimmydean's Avatar
That's the kit I got. The seal I need is the large metal seal that presses into the hub and sits against the large rubber seal. It sits just outside of the needle bearing in that kit.
I am taking the seal back in today to see if we can match it up. If not, I will take a picture.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 06-29-2007, 12:11 PM   #6
earl87gta
earl87gta's Avatar
This is who I get my parts from for my axles he is a 4x4 guy so he knows what your talking about when you need somthing. mike@partsmike.com.
Earl
68 2500 4x4 GMC Burb
earl87gta is offline   Reply With Quote
Old 06-29-2007, 12:25 PM   #7
jimmydean
jimmydean's Avatar
The one on the box is the original, the other one was what NAPA had with the same ID/OD measurements.
I have a feeling I will need to rebuild the whole axle within the year based on how bad this side was. So for now I just want it back together so I might drive it. I will see about a complete rebuild kit and make that a Spring project when I redo the spring lift as well.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 06-29-2007, 12:58 PM   #8
msgross
msgross's Avatar
That's the seal that holds the inside hub bearing on. It doesn't to the axle at all, did you mean spindle?
Looks at my build thread and I might have some ideas for you... I did my u-joints at the same time, they were $15 ea.
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 06-29-2007, 09:40 PM   #9
vectorit
What?
vectorit's Avatar
I have an original GM parts counter book that I have used as my bible for my Suburban, and found that if I know the GM part number I can get it straight from GM. You just need the part # to give to the parts guy at a Chevy dealer, otherwise he or she won't be able to help you since they no longer have these old books. But, they do have the ability to look up part numbers on the "main system".
I have been able to order some really obsure chassis stuff from this book, that no one knew what the heck I was talking about till I gave them a part number.
If you are still having a hard time, let me know and I will scan the page you need. It shows an exploded view of the axle, with every part involved along with GM part numbers to each one.
Chris
1968 K20 Suburban
1972 K10 LWB PU
vectorit is offline   Reply With Quote
Old 06-30-2007, 12:26 AM   #10
jimmydean
jimmydean's Avatar
That would be awesome! The seal I got "works", but I don't like it. email me at d_r_mcdermott@yahoo.com if you'd like to send it, or just PM.
That's great!
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 06-30-2007, 06:16 AM   #11
That kit you got from Napa is a spindle kit.That`s why the inner bearing seal wasn`t included.Pep Boys or anywhere will have it.I can get numbers from the 46-72 10-20 book,too.Some parts are deadend,though.What you`ll get will not be n.o.s.Just repackaged parts.The last bearings I got were Japanese and that was 15 years ago.
Old 06-30-2007, 06:57 AM   #12
msgross
msgross's Avatar
I bought the same kit but didn't have to use the metal flange part... My axle shafts had that part alreay installed too.... It should come with a new inner wheel bearing I would think...
The Garage:
Old 06-30-2007, 12:37 PM   #13
jimmydean
jimmydean's Avatar
OK, next question:
I got everything bolted up and now the drive axle is tight. Is it because the seals are all new, or is something wrong?
I can spin it when I just have the axle in the tube, but when I mount the hub, it's so tight, I can't spin it by hand. I have taken everything apart and put it back together and it's the way I took it out. So is it supposed to be that tight? Or am I screwed?
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 06-30-2007, 11:11 PM   #14
msgross
msgross's Avatar
are both axles like this? Is it an open carrier? are the lockouts locked? wheels jacked up? diveshaft hooked up? need a little more info...
By the way you explain it you have something jammed. Did you bolt on the entire system, spindle, brake plate, hub, , lockouts, tire?
The Garage:
Old 07-01-2007, 01:53 PM   #15
jimmydean
jimmydean's Avatar
I will try to explain.
The front axle is on stands. The drivers side wheel is off to replace the drive axle. I pulled apart the driver side and while I was in there, I replaced the bearing and seal in the hub along with the inner hub seal (see picture above).
When I have the hub bolted on with the brake plate, I can no longer turn the axle shaft. If I unbolt the hub, I can spin the drive axle freely. The transfer case is in neutral, so the drive shaft spins with the driver side axle shaft.
Everything is installed the way it cam off, only with new axle shaft bearings and seal.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 07-01-2007, 11:02 PM   #16
msgross
msgross's Avatar
Is that the axle that I sent you? Does it look like it's going in all the way?
You didn't use the big metal ring that came in the NAPA kit did you? I didn't need it on mine since that piece is built into the short axle shaft....
The Garage:
Old 07-01-2007, 11:12 PM   #17
That deflector presses onto the shaft.It`s a seperate piece and sometimes gets damaged,so they provide it.When you say you bolt the hub to the brake plate,you mean the spindle to the knuckle which has the backing plate bolted to it with the one bolt,right?It won`t spin real freely with the good parts and packed with grease.When you turn it,what does it take to turn?Can you grab the yokes and move it by hand with resistance?
Old 07-02-2007, 01:24 AM   #18
jimmydean
jimmydean's Avatar
There are 6 bolts that hold the spindle to the knuckle and the disc plate goes on there too. Right now I have two bolts (top and bottom) holding the spindle and brake plate to the knuckle and I can't spin that side drive axle by hand.
msgoss, that is the axle shaft you sent me. I pulled the metal ring off since the NAPA kit came with a new one.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 07-02-2007, 06:53 AM   #19
In that kit,what did you get for the inner-most washer,I guess you`d call it?The original is bronze.It`s the first thing that goes on the stub axle.I think most new ones are nylon,I`ve heard.It could just be that snug.I had ended up with two bronze ones on and couldn`t get the snap ring on at the outer tip of the axle.That was on a quicky repair where I couldn`t clean everything up right.It had me baffled for awhile.The only thing that can make that kind of resistance would be that spindle bearing being too snug on the axle shaft.Could you disconnect the rear driveshaft and idle the truck in low range to test it if nothing else obvious is found?It may be just that tight on tolerance.If the spindle slid on the knuckle without forcing and it seated ok,I think you should be ok.It`s hard not being there,but I would do what I just suggested.Give it a try.
Old 07-02-2007, 08:42 AM   #20
msgross
msgross's Avatar
Might need to take the diff cover off and see whats happening inside there... Tim is talking about the "thrust washer" or spacer I think. I will look for the nice exploded pic that I used to repair my axles. The axle shaft should still have some in and out play when the spindle is on, not much but it should be that tight....
The Garage:
Old 07-02-2007, 11:11 AM   #21
jimmydean
jimmydean's Avatar
In that kit,what did you get for the inner-most washer,I guess you`d call it?The original is bronze.It`s the first thing that goes on the axle stub.I think most new ones are nylon,
The nylon washer goes on the drive axle and sits inside the rubber ring that went on to the new metal ring pressed on the outer drive axle, right?
So on the axle I have:
After the u-joint, the metal ring pressed on
Rubber seal on the metal ring
Nylon washer
Then on the hub:
Outer most seal (3" metal seal)
Inner roller bearing that the axle sits on
I can slide the hub over the axle easy. It pressed up until the last 1/4" or so. I can thread the nuts on the bolts. The axle moves at that point. It's when I tighten it down that the axle gets too snug to move freely. I will take some pictures tonight.
Some exploded view shots would be great though.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 07-02-2007, 11:21 AM   #22
msgross
msgross's Avatar
somethings not right... The hub never actually touches the axle until you put on your lockouts. if the axle moves freely with the spindle and backing plate on then it should move freely with the hub slid on it too..... I assume that you have the rotor on the hub?
The Garage:
Old 07-02-2007, 11:37 AM   #23
jimmydean
jimmydean's Avatar
What is "46" in that picture? Other than that, it looks just like mine.
47, 48, 49a, and 50 came in the kit from NAPA. 49 is the big seal that nobody knew about, but I don't know what 46 is. Does that go on before 47 goes on? It wasn't on there on the axle you sent me.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
Old 07-02-2007, 12:00 PM   #24
msgross
msgross's Avatar
46 is the axle shaft itself....
The Garage:
Old 07-02-2007, 12:44 PM   #25
jimmydean
jimmydean's Avatar
Well, then I don't know what the deal is. Guess I will just bolt it up and see what happens.
I have the front on stands, I will put the back on stands and see what happens when it's engaged.
Plans:
1/2 ton conversion
Dropmember front
Dropmember rear
Corvette discs
Restored raised bed
