Old 09-26-2019, 05:56 PM   #1
kens65fb
Plywood bed for working truck
I need to replace the rotted bed-wood in my short fleet box.
This truck will do some light hauling, and I don't want to install new bed-wood & strips.
I was thinking about treated 3/4 plywood, and maybe a rubber bed mat.
Has anyone installed plywood in their bed
Any Pics ??
kens65fb is offline   Reply With Quote
Old 09-26-2019, 09:20 PM   #2
Clyde65
Clyde65's Avatar
Re: Plywood bed for working truck
I wouldn’t do the bed mat unless you take it out after use. They hold water under so...
Treated plywood is a good idea, you will need two 4x8 sheets.
3/4”
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
Old 09-26-2019, 09:53 PM   #3
vince1
It should work. I guess you will have to put a 1" strip across the front. With tongue and groove, if you plan on using it, I can't remember if they do all 4 sides or just the long sides. I think just the long sides.
Edit: I just noticed you have short box so regular plywood is long enough. I'd still go with the tongue and groove to join in the middle.
vince1 is offline   Reply With Quote
Old 09-26-2019, 11:00 PM   #4
SkinnyG
SkinnyG's Avatar
Pressure Treated might start to rust/dissolve the steel?
1961 Apache: "Grabber Orange" Shortboxed, pancake, step-notch, air-ride, turbo, LS
1977 Silverado: Shortboxed & dropped, potato-potato
V8 Pontiac Firefly (Chevy Sprint): The ultimate engine swap: 5.7L in a 1.0L bag
Lotus Super 7 Replica: Scratch-built street-legal rollerskate
SkinnyG is offline   Reply With Quote
Old 09-27-2019, 01:23 AM   #5
AcampoDave
AcampoDave's Avatar
I used exterior grade plywood. 2 sheets split down the middle with the the original strips refurbished and layed on top. I cinched it all down with carriage bolts thru the top and used washers and nylock nuts below. This job was done with 5/8" because it doesn't haul much heavy stuff. I have used 3/4 before too but it makes the strips stick up just a tiny bit above the rear cross sill, which is fine as long as you remeber that and don't go raking a sheet of drywall or similar vulnerable cargo over the raw edges. Also, for anyone thinking of doing a longbed truck, it will need 9 foot sheets which are availabe at real lumberyards.
AcampoDave is offline   Reply With Quote
Old 09-27-2019, 01:37 AM   #6
Lil Loafer
For a temporary bed until I can get nice wood I used non treated plywood on mine and sealed it myself. It started to warp in less than a year, but other than that it is plenty strong enough and has held up for occasional hauling.
1966 c10
1937 Willys truck
Lil Loafer is offline   Reply With Quote
Old 09-27-2019, 08:23 AM   #7
PGSigns
PGSigns's Avatar
I use mine as a truck and haul all kinds of stuff. I have white oak in mine and the stainless bed strips. Works good. The bed strips make it easier to slide stuff in. I am getting ready to redo my old 66 C20 and we are using the southern yellow pine in that one. Was cheaper than the 2 sheets of Marine plywood we would have needed.
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 09-27-2019, 09:37 AM   #8
verdell
verdell's Avatar
Plywood from Lowe’s. Took this pic right before I bolted it down.
verdell is offline   Reply With Quote
Old 09-27-2019, 12:36 PM   #9
rcg66
rcg66's Avatar
I used 2 sheets of regular 3/4" tongue & groove plywood in my longbed. I primered it, and then sprayed it with rattle can bedliner.
I relocated the gas tank in the bed, and found that regular exterior paint didn't like any gas splashing on it.
It has held up really well for over 5 years now.
I ran a bead of silicone down the seam in the middle just for peace of mind.
I don't drive it a lot in the weather, but I have hauled stuff in it and it is still in really good shape.
I do have the gap at the back that I didn't fill in with anything.
rcg66 is offline   Reply With Quote
Old 10-04-2019, 10:18 AM   #10
Android04
Android04's Avatar
I did the same as above and then put the original strips back over top of it. Let me see if I can find a picture somewhere.
Android04 is offline   Reply With Quote
Old 03-31-2020, 11:55 AM   #11
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
Do you remember how much 4x9x3/4 cost?
I lost my 65 - Found it 25 years later:
http://67-72chevytrucks.com/vboard/s...d.php?t=426650
66 C20 Service Truck:
http://67-72chevytrucks.com/vboard/s...d.php?t=428035
LostMy65 is offline   Reply With Quote
Old 03-31-2020, 06:45 PM   #12
AcampoDave
AcampoDave's Avatar
Sorry, I don't remember. That was over a decade ago.
