Old 12-08-2003, 11:51 PM   #1
cb
ls1 pics
A.K.A. my picture posting test.
Craig Berland
cb is offline   Reply With Quote
Old 12-09-2003, 12:08 AM   #2
dinnut
dinnut's Avatar
wow - that looks complicated
70 longbed
496/th400/Ford 9"
dinnut is offline   Reply With Quote
Old 12-09-2003, 12:12 AM   #3
imdarren
imdarren's Avatar
Did you have to modify any sheetmetal to get that motor to fit in there?
Can you use a TH350 trans. or do you have to use something else?
Darren
Washington State
1967 Chevy C10 LWB Rodstoration In Progress.
1972 K20 Cheyenne Super
imdarren is offline   Reply With Quote
Old 12-09-2003, 12:16 AM   #4
Canadian694x4
Born To Lose Club
Canadian694x4's Avatar
Location: Calgary, Alberta/Oxenden, Ontario, Great White North
...I second that...but looking good tho...
Brian Smith - "Born To Lose"
1969 Chevrolet K10 LWB Fleetside - Proud Owner For 22 Yrs - 1 of 208 Built & Sold In Canada!- 283 V8/350TH/NP208, 2" All Spring Lift, 32" Good Year MT/R's.
1972 GMC K2500 Custom LWB Fleetside - Proud Owner For 3 Yrs - 1 of 571 Built & Sold In Canada! - 350 V8/SM465/NP205, 4” Rough Country Lift, 33” Interco TSL Thornbirds
2007.5 GMC Sierra SLE 2500HD 4x4 - Proud Owner For 17 Yrs- 6.6L V8 Duramax Diesel/Allison 1000, 2" Lift, 33" Mickey Thompson MTZ's.
2008 Yamaha Raptor 700r - Proud Owner For 15 Yrs - ITP Mud Lites.
2015 John Deere 1025R - Proud Owner For 8 Yrs - 24HP Diesel/H120/54D/260B/SB1154.
Canadian694x4 is offline   Reply With Quote
Old 12-09-2003, 01:20 AM   #5
Injected68LS1
Injected68LS1's Avatar
Looks great. I've been there before. It takes a lot of work to get these engines installed. But all your hardwork it VERY worth the performance of it.
1968 Chev SWB with 1998 Corvette LS1
305hp and 320 ftlb to the wheels (stock engine!)
AEM EMS and wideband O2 sensors
Bowtie Overdrive's 700R4, stage 3
Baer 4 wheel discs and 20s
http://iciclelanding.com/aperture?album=2049&view=album
Injected68LS1 is offline   Reply With Quote
Old 12-09-2003, 01:27 AM   #6
krue
Designated A-hole!
krue's Avatar
What kind of HP you expecting to get out of that? Definitely looks like a heck of a lot of fun!
"If it ain't broke, fix it 'til it is!"
Being stupid ain't illegal.
We're Still Debt Free Except for the House!!!
www.daveramsey.com
70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e
93 S-10 "Poppaw's Truck"
krue is offline   Reply With Quote
Old 12-09-2003, 01:52 AM   #7
D-Money
D-Money's Avatar
I really like that setup. What tranny are you using? Are you doing the work. I just put an LT1 in my truck with a 700R4. Haven't started it yet but can't wait!
1969 Chevy SB Truck under construction hopefully will be done early next year! Will be posting pics soon.
D-Money is offline   Reply With Quote
Old 12-09-2003, 01:59 AM   #8
lukecp
Formerly yellow72custom
lukecp's Avatar
Sweet....the LS1 is one heck of a motor...i would love to put one in my truck too
'72 Chevy C10 Mild 350/TH350/3.07. Ochre/White. Old high school ride.
'70 GMC C2500 '62 327 4bbl/SM465/4.56-geared Dana 60. White/White. Project or parts truck.
'97 Saturn SL DD. 1.9/5-speed. 40+ highway mpg
lukecp is offline   Reply With Quote
Old 12-09-2003, 02:01 AM   #9
dinnut
dinnut's Avatar
what is the deal with the ls1. they sell parts just for it... is it different than most engines?
70 longbed
496/th400/Ford 9"
Old 12-09-2003, 02:06 AM   #10
lukecp
lukecp's Avatar
Yes it is completely different than the old-style small blocks....i think the only interchangable parts are the cam bearings.
The new 4.8/5.3/6.0 truck motors also have the same basic design, but are iron, wheras the LS1 and LS6 are both allumium
Old 12-09-2003, 02:34 AM   #11
N2TRUX
Happy to be here
N2TRUX's Avatar
I can't speak for cb, but I can answer some of your questions. You have to run an E-series transmission. That means either a 4L60E or a 4L80E. The computer tells the transmission what to do, and any non electronic controlled transmission won't work.
The LS1 is the new generation GM small block. It has an aluminum block, and aluminum heads. The 4.8, 5.3, and 6.0 are the same motor, but use a cast iron block with aluminum heads. They LS1 and LS6 use a low profile plastic intake designed to fit under the hood of Camaros or Corvettes.
The 4.8, 5.3, and 6.0 use a high rise style plastic intake for low end torque....
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-09-2003, 02:57 AM   #12
sinister72
sinister72's Avatar
i can speak from experience but you can use a TH350 or th400 tranny if you so choose with the LS1 engine. i have used the combo in a 00 Trans Am that i drag raced. all it takes is an adapter plate. the LS1 and LS6 plastic intakes and cyclinder heads will also bolt directly to the 6.0 and the 6.0 and 5.3 heads will bolt onto the LS1 engine. in my opinion i would use the 6.0L truck engine and use Lunati's 4inch stroke crankand rods and pistons to go out to 408 cubes. have the 6.0l heads ported, throw on a LS6 intake and throttle body and mass ait and related components. i have seen similar combos produce over 450hp and idle smoothly while pulling down decent gas mileage. this is al by far not cheap, but well with in reach.
72 chevy C-10 swb fleetside,402 BB.700r4,buckets,console.etc.
72 Blazer CST 350,AT, new project
1971 Chevy Nova ,355 SB blow through turbo in works.
sinister72 is offline   Reply With Quote
Old 12-09-2003, 11:04 AM   #13
N2TRUX
Happy to be here
N2TRUX's Avatar
sinister72 you are correct. You can run any transmission you choose I suppose. But none of these will bolt up, like you said.
I was told by a number of companies that a non electronic transmission would not work. I based my response on the information provided by these companies.
I just read an article in the December issue of Classic Trucks where they are doing an LS1 install using a 700r4. So it can be done.
Old 12-09-2003, 12:49 PM   #14
Injected68LS1
You can actually bolt up a th350, th400, 2004r or a 700r4. I'm using the 700r4 behind mine. The only difference in the bellhousing pattern of the transmissions and the Ls1 is one of the top bolt holes doesn't exist on the block. It's plenty strong with the other 5 bolts.
You would also need to buy a flexplate adapter from several different companies that make one. I bought mine from Yank Converters. Then you can buy a TV cable for the LS1 from Bowtie Overdrives. That's all it takes.
Old 12-09-2003, 05:38 PM   #15
Ackattack
Ackattack's Avatar
If I were to install an LS1 in my truck with an automatic, I'd go with the 4L60E that they come with, unless you're really into drag racing. The 4L60E can hold up to some power and you'll get overdrive and don't have to mess with any conversion headaches.
Of course if I put an LS1 in my truck, I'd go with a six speed, but I'm a little biased
I would like to see someone put a new 5.3L in on of these trucks. I think it would be cheaper to purchase the engine than the LS1, just because there are so many more of these out there.
Check out www.ls1tech.com for more information than you need to know about the LS1.
Ackattack is offline   Reply With Quote
Old 12-09-2003, 05:41 PM   #16
Project1970
14.1 @ 96MPH
Project1970's Avatar
You can put a non-electronic tranny behind it just fine if you just reprogram the ECM to think it's got a manual behind it - all it needs from a manual car is the speed!
Project1970 - LS1 Swap Complete!
Project1970 is offline   Reply With Quote
Old 12-09-2003, 10:45 PM   #17
cb
To answer a few questions:
To put in a ls1 from a F-body, you need to notch a little bit of frame away to clear for the ac compressor. The ls1 has a distributerless ignition, so firewall clearance isn't an issue. My firewall is modified to fit a ls1 ac unit, not because of the motor to sheetmetal clearance.
Horsepower is about 325 stock I beilive- I wont be running cats, and will have a low restriction exhust... dont know how much it will add.
Im running a 4l60e, wich is an automatic 4 spd.
BTW that picture was taken about a 1.5 yrs ago, looks alot different now... still not done.
Craig Berland
Old 12-10-2003, 12:12 AM   #18
TEXAS 68
Vortec in the works
TEXAS 68's Avatar
How about some updated pics.
68? It's all figured out untill you get it apart.
Is it Sunday yet???
68 Project
68 SWB frame off/98 Vortec with stock FI/power everything.
95 ECLB 2500 with 346,000 on the clock(the original HD)
99 Lesabre-wifes ride
08 Crew Cab LTZ-All Mine
89 SWB 5/7 drop-Son's first ride.
TEXAS 68 is offline   Reply With Quote
Old 12-10-2003, 01:48 AM   #19
68c10owner
68c10owner's Avatar
i called the local yard that sells the late model motors to alot of streetrodders and for $3,500 i can get a 5.3 with trans and all acc.,exhaust,computer, everything i need. the 6.0 was $4,500. i called about a year ago for the LT1 and it was $4,000. i`m thinking about doing a 5.3 or 6.0 liter swap into my 68. they are great motors.
Anthony
68c10owner is offline   Reply With Quote
Old 12-10-2003, 03:53 AM   #20
68LSS1
68LSS1's Avatar
Looks good cb. Who's a/c kit are you going to use with the LS1 a/c compressor?
'68 Short Step
LS1/T56, Hydratech, Fatman Fabrications Stage III, Baer, Hot Rods to Hell, US Body, S&W, etc
68LSS1 is offline   Reply With Quote
Old 12-10-2003, 09:41 PM   #21
cb
68lss1
I'm not sure if there is a kit for the compressor, were using the stock ls1 compressor. We also used the stock F-body ac unit, we refabricated the firewall to fit the unit. (About 9 months worth of hell...) Definatily not a kit for that either. Not sure if that helped any?
Craig Berland
Old 12-11-2003, 12:27 AM   #22
cb
My son posted the picture, etc. This is a father/son project that has gone out of control. The LS1 went in with the 4L60E trans and that was the start of several years of fabrication and what I can only call temporary insanity. Next came the '99 Camero A/C unit in the dash, the aluminum/plastic radiator and A/C condensor, and electric fans. Then a total custom dash with the '99 Camero cluster (160 mph speedo, tach, gages, etc. Then the '99 Camero tilt column so we would have cruise control and VATS. Then the pluse windshield wiper motor to go with the controls on the column. The '99 Camero A/C controls are incorporated in the custom dash along with a custom billet glove box and door. Custom console for the '99 shifter between 2001 Silverado seats. The gas tank is '99 Camero with the high pressure in-tank pump. The filler comes out on the top of the passenger step side fender. The gas filler door is from a '99 Cadillac. The rear disc brakes are '79 Seville. The flush door handles are from a 2001 Malibu. We installed the one piece window kit so we decided we needed the new style mirrors from a 2000 S10. This led to power windows, power door locks and power mirrors. Therefore we are now fab'ing custom door panels from a '99 Silverado to incorporate the electric GM contols for the electric door stuff. Oh i almost forgot...the aluminum LS1 prop shaft which required a custom machined yoke connected to a fresh 5-bolt 3.73 eaton posi. So far we have done it all without help. The paint however will go to Henry's Rods and Customs in Mesa, AZ. I think we will get help with the interior as well. It should be finished this spring.
Craig Berland
Old 12-11-2003, 12:54 AM   #23
68c10owner
68c10owner's Avatar
CB, does the camaro LS1 mount the same as the truck style LS1? what did you use for motor mounts? i`ve been playing with the idea if swapping in a 5.3 truck LS1 stlye motor and so far the motor mounts are the only thing i`m concerned about. thanks
Anthony
Old 12-11-2003, 01:02 AM   #24
knucklebuster
Failure is NOT an option!
knucklebuster's Avatar
Hey man!!!,You can't just come on here and tell us about all this Stuff without pics of it all!!!We'll go crazy!!!That sounds like one sweeeet ride man.We'd love pics of it all.
House payment or truck parts?????.........why does life have to be so complicated?
1969 Chevy Shortbed Fleetside
1969 Camaro ps pb a/c(drove in high school now it's just a yard ornament,but it's next on the list for resto)
1990 Ni$$an hardbody( daily beater that has been really beaten!)
1999 Grand Am GT(wifes ride...never buy a pontiac!!Trust Me)
knucklebuster is offline   Reply With Quote
Old 12-11-2003, 01:03 AM   #25
cb
We used the '99 Camero upper rubber mounts that bolt to the engine and fabricated the lower metal brakets. The engine sets nice and low with the A/C compressor down in the frame rails.
Craig Berland
