Old 01-30-2010, 09:37 PM   #1
kyoung
Drag-Link question
I've put a 4" lift on my 68 K10 and went with an adjustable drag-link. The old drag-link had a taper bolt on the knuckle side. The new drag-link has no taper and doesn't seem to want to give enough thread to put a cotter pin through on the bottom side. Do I just need to crank the hell out of it to get it to set into the hole or should it have had a taper?
kyoung is offline   Reply With Quote
Old 01-31-2010, 08:49 AM   #2
Re: Drag-Link question
That doesn`t sound right.Was the part listed for a`68?I`d think all rod ends should be taper-fit.Personally,I don`t like a drop drag link.ou just gave me one more reason.I think the stationary steering arm is the way to go to adjust for height with a newer factory-type adjustable drag link.I think a drag link should be a straight shot without that offset to increase side to side stress on the joints and virtually change the geometry a bit when if rolls ever so slightly from side to side as the suspension travels up and down.I`m no engineer,but that`s what I envision
Old 02-01-2010, 11:23 AM   #3
Yukon Jack
Yukon Jack's Avatar
As you've figured out, with the closed knuckle axle, the adjustable drag link is about the only option as a raised steering arm isn't available. I used the same drag link as you are using on my 69 K20 and it definitely fit differently than yours.
I'm assuming your arm has a taper to the hole. I can look at my drag ling end tonight as I have one of those pulled presently but I'm just certain it has a taper to it.
If it doesn't have a taper, I'd be very reluctant to put alot of torque to it - something is wrong. Maybe give the manufacturer of the drag link a call.
1970 Blazer with a 400 sbc and 4" lift
1980 Pontiac Trans Am, 455 Oldsmobile
2012 Kawasaki Concours 14
Yukon Jack is offline   Reply With Quote
Old 02-01-2010, 11:23 PM   #4
I wondered about raised steering arms for closed knuckles being made or not.
Old 02-02-2010, 11:18 AM   #5
Yukon Jack
Yukon Jack's Avatar
Here's a pic of the drag link end showing the taper your end should have
Old 05-09-2020, 05:54 AM   #6
gmc 2500 4x4
good info, i was getting ready to buy one
gmc 2500 4x4 is offline   Reply With Quote
Old 05-09-2020, 12:49 PM   #7
sweetk30
sweetk30's Avatar
the pics of the original poster has a few problems . . . . yes i know old thread someone dug up .
the first is the tapper size is smaller a lot more on the older rigs than the newer ones . easy to fix with the correct 1.5" per foot tapper reamer common for automotive use . https://www.ruffstuffspecialties.com/catalog/REAM.html yes it says 1ton size . but the tapper is the same its just how deep / big you make the hole to the size of the joint being used .
next is the angle his new S-shaped drag link is at is WAY to much . notice the ends are pointing way off . the drag link should have a slight down angle when the vehicle is on level ground and weight on it . his pic shows the threaded end at the box pointing up and the axle end down . this is NOT going to handle good at all . and even worse as the suspension flexes down .
hope this info helps and if any more questions just ask .
77-k30lb BIG truck build .
87-k30lb budget beater build .
85-k30lb the plow machine build .
85-c10sb summer fun toy .
HOLLEY SNIPER efi = worst case of p.i.t.a i ever had .
EDELBROCK pro flo 4 = best deal going so far . love my setup works great.
sweetk30 is offline   Reply With Quote
Old 05-09-2020, 01:13 PM   #8
gmc 2500 4x4
Thanx for the info, I wasn't getting a full left turn, I put on an adj drag link which was to long, I shortened both links 1/2" , all good. And I run the drop pitman arm
Old 05-10-2020, 09:50 PM   #9
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
I was just going through the same thing over the last couple days on my K10. I have the Skyjacker 2-1/2" lift, but never had the drop arm. I just bought and installed the CA50 drop pitman arm. I also wanted to replaced my drag link since my old one was a mess. I bought the Moog ES2027L link at pitman arm, Moog ES2026R outer and Moog 41822RM adjusting sleeve.
First I adjusted the tie rods to get my front wheels pointed perfectly straight. With my tires removed, I used a 3' level against the ends of the wheel studs and measured off the leaf springs back to the level and got both sides adjusted perfectly. With my pitman arm in dead center, and steering arm in dead center I was not able to get my drag link installed. I ran out of adjustment as the ends of the links butted up against each other in the adjusting sleeve. I had to take about 1/2" off one the drag link rods in order to get it adjusted right.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 05-11-2020, 02:26 PM   #10
61K10
61K10's Avatar
this is what i used with no mods--es2027L tie rod end--es2234R tie rod end and es 362s sleeve.
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 05-11-2020, 02:28 PM   #11
gmc 2500 4x4
Good to know !
Old 05-11-2020, 02:38 PM   #12
derotoreut
derotoreut's Avatar
I wonder if the different year matters somehow? Or maybe the drop pitman arm? It would be sad if the ones made in Taiwan fit better then ones made in the USA.
~ Dan
Old 05-11-2020, 02:43 PM   #13
61K10
61K10's Avatar
One of the tie rod ends is the right taper for the steering arm. Don't remember which one.
1961 chevy K10
